> Got salt?
emerygt350
post Jan 30 2022, 12:08 PM
Why yes, that is dry pavement.
914_teener
post Feb 2 2022, 12:16 PM
I am in Northern AZ part time where in the Winter it's very common to have snow.
Mostly they use ground pumice as salt is a killer for road surfaces and concrete long term...(I'm a civil engineer). The snow is short lived there genereally but sometimes NOT in my north facing driveway. When I resruface the driveway I'm looking into a paver systems and some type of radiant heating to de-ice it.
As everyone may know by now, bridge appraoches are notorious for icing becuase of the massive thermal mass of the concrete which tends to ice once it reaches gradient temperature. The uses of clorides like salt do massive damages to those approaches and particulary steel structures with concrete decks built back in the seventies.
It's cheap yes but long term the true cost of degradation of roads and bridges is in the billions of dollars.
Be responsible and learn how to drive. I don't expect anyone else to pay for my negiligence in that regard.
One of the reasons I got the Macan P car....AWD on demand. It's an amazing handler in snow with the right tires.
wonkipop
post Feb 3 2022, 12:44 PM
QUOTE(914_teener @ Feb 2 2022, 12:16 PM) *
yes - there has been a few bridge collapses in recent years in the USA.
salt and reinforced concrete or steel are not best of friends.
that all catches up as you say.
then its a very big bill and a lot of pressure on govt. budgets to fix it.
these things have a habit of starting to all fail at the same time too.
awd makes a lot of sense in northern regions of the usa.
(makes sense anywhere when you think about it).
914_teener
post Feb 3 2022, 01:56 PM
QUOTE(wonkipop @ Feb 3 2022, 10:44 AM) *
Traffic control is all about liability. The Northeastern US uses a lot of salt because....it's a cheap way to de-ice and they have prolonged periods of freezing and sometimes subfreezing temperature.
In AZ...they put a sign well before the bridge warning you....and if you didn't know this about bridge approaches during freezing periods then you should. Normallly the periods of freezing temps don't last as long, so they use crushed pumice instead. Not great for the windshield though, but it's better for the roads and bridges.
That bridge that failed recently wasn't designed to last more than 50 years and the City that was in charge of it ---Pittsburg...likely didn't have the money to pay to fix it.
We'll see what the NTSB comes up with.
I'ts just blind luck nobody was killed.
930cabman
post Feb 3 2022, 02:19 PM
[quote name='914_teener' date='Feb 3 2022, 02:56 PM' post='2979257']
[quote name='wonkipop' post='2979240' date='Feb 3 2022, 10:44 AM']
[quote name='914_teener' post='2979043' date='Feb 2 2022, 12:16 PM']
[/quote]
[/quote]
Shame on the city of Pittsburgh, nothing short of a miracle nobody was seriously injured or killed. Here in Sunny Buffalo the forecast is about 30 hours of steady snow.
Best bet is to steer clear of the idiots, cause there are many
flipb
post Feb 3 2022, 02:54 PM
QUOTE(930cabman @ Feb 3 2022, 03:19 PM) *
Before you cast stones: 9.4% of bridges in NY Congressional District 26 (home to Buffalo) are currently structurally deficient.
Look up any state/district here.
914_teener
post Feb 3 2022, 04:37 PM
QUOTE(flipb @ Feb 3 2022, 12:54 PM) *
I'll stand by my stones. The bridge was under the jurisdiction of the City of Pittsburgh and fell on the Interstate under FWHA jurisdiction. In 2017 they changed the overall rating for bridge evaluation by limiting it to cetain key elements instead of overall.
So if anything there that failed wasn't technically a key element...then it didn't make that list.
The bridge that failed in Pittsburgh was overall a "4" so thus...didn't rate to be closed. I suspect it will be a while before the NTSB report comes out but I'll bet they'll be looking closely at how the rating system relates to the poor soul or company that did the inspection. Not long ago a guy was drifting down the Mississippi River and saw and documents a huge crack in a tension strut on the I-40 Bridge. Turns out it had not long ago been inspected by ONE guy. They changed that rule too...that two people had to inspect.
Off track here or else Clay will close the thread down...
Get AWD P car and learn to drive
Also avoid the bridges on that list if you can. (IMG:style_emoticons/default/laugh.gif)
emerygt350   Got salt?   Jan 30 2022, 12:08 PM
Van B   Checks… I won’t be driving either Porsche unti...   Jan 30 2022, 12:20 PM
ClayPerrine   EWWWWWWW Nasty white stuff covering the ground......   Jan 30 2022, 12:23 PM
Van B   [size=5][b]EWWWWWWW Nasty white stuff covering t...   Jan 30 2022, 12:40 PM
wonkipop   it looks purty when it first falls. as i remember...   Jan 30 2022, 03:24 PM
StarBear   it looks purty when it first falls. as i remembe...   Jan 30 2022, 03:30 PM
wonkipop   it looks purty when it first falls. as i rememb...   Jan 30 2022, 03:45 PM
emerygt350   For those of you that may not experience this... ...   Jan 30 2022, 04:38 PM
930cabman   For those of you that may not experience this... ...   Jan 30 2022, 05:33 PM
ClayPerrine   For those of you that may not experience this... ...   Feb 1 2022, 07:08 AM
emerygt350   Luckily the Porsche is trapped behind feet of snow...   Jan 30 2022, 07:02 PM
bkrantz   Careful! Even talking about salt near a 914 c...   Jan 30 2022, 10:02 PM
wonkipop   dumb question from dumb australian. but why the f...   Jan 31 2022, 02:32 AM
930cabman   dumb question from dumb australian. but why the ...   Jan 31 2022, 06:04 AM
bkrantz   dumb question from dumb australian. but why the...   Jan 31 2022, 09:36 PM
PatrickB   dumb question from dumb australian. but why the ...   Feb 1 2022, 04:22 PM
930cabman   dumb question from dumb australian. but why the...   Feb 1 2022, 05:24 PM
74ravenna   Why yes, that is dry pavement. Yep, that's...   Jan 31 2022, 05:24 AM
mlindner   Wisconsin last week -23 deg in the morning.....But...   Jan 31 2022, 06:39 AM
VaccaRabite   http://www.914world.com/bbs2/uploads_offsite/live....   Jan 31 2022, 08:46 AM
dhuckabay   Think you will find that this is magnesium chlorid...   Jan 31 2022, 10:15 AM
Van B   That checks. The brine is designed to not wash awa...   Jan 31 2022, 09:00 AM
beech4rd   That checks. The brine is designed to not wash aw...   Jan 31 2022, 09:10 AM
VaccaRabite   That checks. The brine is designed to not wash a...   Jan 31 2022, 09:42 AM
Van B   In my limited experience (since 2019), the rock sa...   Jan 31 2022, 09:46 AM
Shivers   In my limited experience (since 2019), the rock s...   Jan 31 2022, 10:15 AM
emerygt350   In minnesota, where it used to be regularly too co...   Jan 31 2022, 12:48 PM
Superhawk996   In minnesota, where it used to be regularly too c...   Jan 31 2022, 02:02 PM
wonkipop   In minnesota, where it used to be regularly too ...   Jan 31 2022, 03:01 PM
wonkipop   In minnesota, where it used to be regularly too c...   Jan 31 2022, 02:56 PM
JmuRiz   Looks like my roads, brined before and salted duri...   Jan 31 2022, 07:37 PM
Van B   Looks like my roads, brined before and salted dur...   Jan 31 2022, 08:29 PM
Front yard mechanic   In New Mexico we just toss dirt on the road in the...   Feb 1 2022, 07:32 AM
930cabman   In New Mexico we just toss dirt on the road in th...   Feb 1 2022, 03:25 PM
iankarr   As much as I hate salt...sand might be worse since...   Feb 1 2022, 01:46 PM
wonkipop   there is a place in aus to drive on salt with a sm...   Feb 1 2022, 03:56 PM
Superhawk996   there is a place in aus to drive on salt with a s...   Feb 1 2022, 04:08 PM
wonkipop   there is a place in aus to drive on salt with a ...   Feb 1 2022, 04:24 PM
emerygt350   When I lived in Washington DC we had an inch or so...   Feb 1 2022, 07:41 PM
SKL1   Having lived full time in AZ for the last 2 years,...   Feb 1 2022, 10:27 PM
914_teener   I am in Northern AZ part time where in the Winter ...   Feb 2 2022, 12:16 PM
Superhawk996   Be responsible and learn how to drive. :rotfl...   Feb 2 2022, 12:41 PM
914_teener   Be responsible and learn how to drive. :rotf...   Feb 2 2022, 01:42 PM
ClayPerrine   (I'm a civil engineer). Remember, Mechani...   Feb 2 2022, 02:59 PM
worn   In the early spring here in Wisconsin, say late Ma...   Feb 2 2022, 06:48 PM
wonkipop   I am in Northern AZ part time where in the Winter...   Feb 3 2022, 12:44 PM
914_teener   I am in Northern AZ part time where in the Winte...   Feb 3 2022, 01:56 PM
930cabman   [quote name='914_teener' post='29790...   Feb 3 2022, 02:19 PM
flipb   Shame on the city of Pittsburgh, nothing short of...   Feb 3 2022, 02:54 PM
914_teener   Shame on the city of Pittsburgh, nothing short o...   Feb 3 2022, 04:37 PM
flipb   Usually, even during the winter, we get at least a...   Feb 3 2022, 10:13 AM
mlindner   Funny worn, I think you've been cooped up to l...   Feb 3 2022, 12:00 PM
914_teener   Funny worn, I think you've been cooped up to ...   Feb 3 2022, 01:35 PM
emerygt350   That bridge in Minneapolis always scared me when I...   Feb 3 2022, 03:40 PM
914_teener   That bridge in Minneapolis always scared me when ...   Feb 3 2022, 05:01 PM
StarBear   Getting back to salt.... My wife worked for a lo...   Feb 3 2022, 06:35 PM
emerygt350   I used to deliver pizza in a dodge Omni during 50 ...   Feb 3 2022, 06:36 PM
VaccaRabite   Snow tires are the bomb. My WRX with a set of sno...   Feb 3 2022, 07:04 PM
Shivers   I live in the low desert in So. Cal, and we have s...   Feb 3 2022, 07:12 PM
emerygt350   That hurts. We have 8 inches of old snow with a t...   Feb 3 2022, 07:36 PM
targa72e   I remember the discussion when I lived in Michigan...   Feb 4 2022, 11:05 PM
- Lo-Fi Version Time is now: 27th October 2026 - 06:40 AM
