> Windshield Trim Removal
Shredhead
post Feb 6 2022, 01:07 PM
I need to pull mine in prep for painting. I've read everything I can and watched some videos, but I'm still confused regarding removing the trim. Other than cutting through any sealant/gunk, what do you need to do to free the trim from the clips (assuming they're still there)? Use a tool like Chris Foley's to push the trim off the clip?
iankarr
post Feb 7 2022, 03:54 PM
If the glass is coming out (and why wouldn't it for a repaint (IMG:style_emoticons/default/wink.gif), the easiest way to remove the trim is to "chop" the clips using a very thin putty knife between the trim clip and the channel, directly over the pin which holds the clip to the body. A quick hit with a hammer and the plastic pin holding the clip breaks. Then you can lift the trim off as a single piece- clips and all. Remove the broken clips on the bench. Of course, you'll need to replace with new trim clips after paint and before the glass goes back in.
Shredhead
post Feb 8 2022, 07:48 AM
QUOTE(iankarr @ Feb 7 2022, 04:54 PM) *
Thanks Ian, and thanks for the video on how to reinstall it!
- Lo-Fi Version Time is now: 3rd March 2026 - 05:24 PM
