Fuel pump not going on?, Drove fantastic....stopped for about an hour...no fuel pump sound |
second wind |
Feb 11 2022, 06:48 PM
Senior Member Group: Members Posts: 856 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hey guys.....took a drive qand loving the 914 and stopped for a while and could not restart the car. I finally noticed there was no ful pump sound..(three port pump mounted by the steering rack. Checked the fuses, swapped out relays with new 914 rubber relays, and still nothing. If anyone wants to share an idea I am all ears. Fuel pump relaticely new...not the original one but identical. Thank you very much !!!
gg |
windforfun |
Feb 12 2022, 11:11 AM
Senior Member Group: Members Posts: 1,801 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
IIRC all the connectors & relays are keyed so there's only one way they can be inserted. The above diagram also indicates this. Also, what was changed between the two states of pump operation (running vs. not)?
second wind |
Feb 12 2022, 01:33 PM
IIRC all the connectors & relays are keyed so there's only one way they can be inserted. The above diagram also indicates this. Also, what was changed between the two states of pump operation (running vs. not)? Nothing changed.....I drove up a fairly flat driveway and parked and when I went to go home no start no fuel pump sound....thank you for your help... gg |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:58 AM |
