914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I got oil pressure and oil temp gauges. The instructions are generic and I'd like some specifics about how to install them on my 1.7L '72. Sorry if these seem obvious; I've never done this before.
1. Standard ground or floating ground? I'm leaning toward floating because it looks obvious how to attach the ground. On the standard ground, how do I attach the gnd wires? 2. What do I attach the wire from the gauge light socket to the light switch to? The headlight switch? Which connector? 3. Which fuse do I use for power? #9? 4. I figure I will just attach grounds to a screw on the body, either an existing one or a new one. 5. What is the "switched +12v" light shown in the instructions? The dummy light? 6. Does the oil pressure sensor get installed where the current oil pressure switch is by the distributor? Doesn't appear to be any room, but I'll need to move some hoses, etc out of the way. 7. Where does the oil temp sensor go? The instructions state that it can replace the drain plug. Is this correct? 8. Where is the best route for the wires? I was thinking thru the middle along where the other wiring harness is located. What should I do with them in the engine compartment: zip tie them to other wires, or let them hang free, or what? If anyone has done this and has pictures or a more detailed description, I'd appreciate it. Attached thumbnail(s) ![]() |
advman89 |
Member ![]() ![]() Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest ![]() ![]() |
Tackling the oil temp sensor. 1971 with a 1975 2.0L
I am replacing the Taco Plate with 914Werks' billet cover, aftermarket VDO sender. The factory wire on there currently is black. and the bracket is attached to the taco plate (the tab / guard / crimped tail)...hoping that comes down easy. In the meantime, I pulled the carpet on the tunnel and there isn't any connectors under there for a center console...so now what? Just when I think I'm getting momentum... |
Lo-Fi Version | Time is now: 1st August 2025 - 08:43 AM |
