> Install VDO temperature guage
advman89
post Feb 13 2022, 05:18 PM
1971 with a 2.0L
Before I pull the current taco plate and factory sensor to replace with 914Werke's billet cover and VDO sender....
Couple questions / issues
Looks like the wire is crimped in to prevent rubbing...is there any advice here so I don't break the wire?
My car doesn't have the leads next to the gear shift for the optional center console...so I need to tap into the existing wire, or do I run my own from new sensor to the gauge?
I know this has probably been covered, but can't seem to find anything using the search engine...
Thanks all!
GregAmy
post Feb 14 2022, 07:04 AM
QUOTE(advman89 @ Feb 13 2022, 06:18 PM) *
In the back? "Be careful." use some needle nose pliers and carefully bend the tabs out.
Are you replacing the factory oil temp gauge? If you don't need it, then there should be a factory connector under where the console would go; you'll just disconnect the green(?) wire there and route it to your VDO gauge. That, of course, means your factory gauge in the combo will no longer function.
- Lo-Fi Version Time is now: 2nd April 2026 - 01:23 PM
