clear brake lines, brakes |
Medtner3 |
Feb 19 2022, 06:00 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
I need to replace the clear brake lines in the front of my 914... could someone possibly tell me the size of the cloth lines under the master cylinder reservoir and the size and length of the clear tubing from under the reservoir?
Can I assume any of the correct size clear plastic tubing would work and could maybe get at the hardware store? Just asking because if that is the case I could fix that this weekend and put my rebuild back on track rather than waiting on parts to ship to me |
bdstone914 |
Feb 19 2022, 09:34 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I need to replace the clear brake lines in the front of my 914... could someone possibly tell me the size of the cloth lines under the master cylinder reservoir and the size and length of the clear tubing from under the reservoir? Can I assume any of the correct size clear plastic tubing would work and could maybe get at the hardware store? Just asking because if that is the case I could fix that this weekend and put my rebuild back on track rather than waiting on parts to ship to me @Medtner3 I think they are 8mm ID. If you use a locally available source make sure it is intended for petroleum use. Most clear hose you find in hardware stores is meant for use with water. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:06 AM |
