| trojanhorsepower |
Feb 23 2022, 06:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Hi All,
Strange question. The rubber fuel lines that come out from under the tank both are kinking right where they leave the tank nipples. I cut them down as short as I can. It still kinked. Its like the nipple is too long, or the tuning is not strong enough. It came from tangerine racing. It gets nasty black all over me if it gets fuel on it. Kind of weird fuel lines would not be ok around fuel.... Thanks, Peter |
| Steve |
Feb 25 2022, 06:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I used wire loom around the gas line under the tank to prevent it from kinking. Wrap it around the line and use tie wraps to keep it from coming off. Similar to the spring idea. I got it at the local Ace hardware store. Something similar to this. https://www.cabletiesandmore.com/black-wire...NgaAixCEALw_wcB
trojanhorsepower Fuel line kink Feb 23 2022, 06:04 PM
nditiz1 If you put a loop in it it should not kink. Check... Feb 23 2022, 07:13 PM
trojanhorsepower Yeah, I thought that was how I had it originally. ... Feb 23 2022, 07:37 PM
bkrantz Make sure you get quality tubing, preferably high ... Feb 23 2022, 08:25 PM
Spoke @trojanhorsepower
I had an issue with Tangerine ... Feb 24 2022, 06:13 AM
trojanhorsepower OK thanks for all the responses. I will pull the ... Feb 24 2022, 04:23 PM
ChrisFoley Ian sent me a note that some fuel hose I sent him ... Feb 24 2022, 05:50 PM
trojanhorsepower Hi Chris,
I purchased my kit a while back so you p... Feb 24 2022, 07:10 PM
TC 914-8 I just redid all my lines with -6 AN fittings and ... Feb 24 2022, 10:46 PM
ChrisFoley All the modern FI hose kinks easily. I have a spri... Feb 25 2022, 04:51 PM
TC 914-8 I just redid all my lines with -6 AN fittings and ... Feb 25 2022, 10:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:46 PM |
