jackspratt |
Member ![]() ![]() Group: Members Posts: 55 Joined: 5-February 22 From: Canada Member No.: 26,315 Region Association: Pacific Northwest ![]() ![]() |
Wondering what this would have plugged into it. Looks like it's a ground of some sort and looks stock? Anyone have a clue? 1973 914 2.0
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
I believe yellow are 1.7 injectors. Not sure how changeable the heads are but I would be careful until you know what is on what with this thing. If you ran a 1900 engine with 1700 injectors it's going to be very lean.
If you are getting pressure in the rail I would look to the injectors and dizzy first. You can turn it over with an injector out to check if they are firing, just put it in a can with a paper towel etc. It is possible they are all gummed up and not firing. Just don't light the car on fire trying. The injectors are cheap so just getting a new ones isn't a terrible idea if you think they might be gummed up. Not sure if I would buy a full set till I knew what I had underneath. Does anyone ever put 1.7 heads on a 2.0? Pulling the distributor is easy, I would do it, and clean the advance/retard plate and clean up the trigger points/ check their condition. ECU rarely goes on these cars. something else to think about is the pressure regulator if the fuel pressure is low. |
Lo-Fi Version | Time is now: 16th June 2024 - 01:57 PM |
