> white-green wire mystery, where do these 2 wires go?
jackspratt
post Mar 6 2022, 10:23 PM
Here is a pic of 2 wires. One green and one white. They are coming off a harness near where the 2 fuel lines fan side are. Next to distributor. Can someone please explain where they plug in to? If they do at all. Also, can't get injectors to fire. and what does that plug with the boot on it that is plugged into the fuel line middle junction do?
Thanks Teeners! Attached Image
914Mels
post Mar 7 2022, 03:29 PM
Took a look at our car, the white wire goes to the thermo time switch which controls the amount of time the cold start valve operates. It's mounted under the intake runners. The other wire is most likely the oil pressure switch wire. The cold start valve is the part you are referring to that has the fuel lines and the two wire connector.
- Lo-Fi Version Time is now: 16th June 2024 - 09:20 PM
