Mystery connection, don't know what plugs into this, have a look |
jackspratt |
Feb 27 2022, 10:22 PM
Member Group: Members Posts: 55 Joined: 5-February 22 From: Canada Member No.: 26,315 Region Association: Pacific Northwest |
Wondering what this would have plugged into it. Looks like it's a ground of some sort and looks stock? Anyone have a clue? 1973 914 2.0
brant |
Mar 9 2022, 11:23 AM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the wrist pin height is different at the pistons for a 1.7 and 2.0
so the motor (any motor) would have to have pistons to match the crank and rods... or things wont fit.... you can change heads with a little machine work between motors most likely you have all 1.7 parts in a 2.0 case. |
JamesM |
Mar 9 2022, 11:58 AM
Senior Member Group: Members Posts: 1,922 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
the wrist pin height is different at the pistons for a 1.7 and 2.0 so the motor (any motor) would have to have pistons to match the crank and rods... or things wont fit.... you can change heads with a little machine work between motors most likely you have all 1.7 parts in a 2.0 case. That would be my bet as well. I suppose its possible the whole bottom end could be 2.0 BUT 1.7 heads won't fit 2.0 cylinders without modifications, and seems unlikely someone would have thrown 1.8 heads on a 2.0 bottom end with 1.7 injection. but i suppose anything is possible. Only way to really know whats in there is to take one of the heads off but given the 1.7 heads and injection I would probably just assume its all 1.7 internals. |
Lo-Fi Version | Time is now: 16th June 2024 - 04:50 PM |
