| DC_neun_vierzehn |
Mar 15 2022, 09:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 640 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I've seen a lot of 914 owners incorporate a 911 oil pressure gauge (and aftermarket oil pressure gauges) into their 914 dash. Since oil level and oil pressure are two different things, what is the oil pressure helping a 914 driver monitor or prevent from happening?
I've never owned a car with an oil pressure gauge. The stuff I'm reading on Google is all over the place and I can't find anything specific to 914s. Thanks in advance for the education. |
| emerygt350 |
Mar 15 2022, 12:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,508 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I agree that it really isn't going to help you if there is a problem but it will help you see the problem coming. Oil pressure lights come on way too late to help minimize damage. Oil pressure gives you a sense if something is going on with your engine. I know how much I get when the oil is cool, hot n hot, on the highway cruising at speed etc. If those numbers change I know something is unhappy (low oil is one of the first things it warns me about). The engine temp gauge + the oil pressure can tell you all kinds of valuable things that can keep you from causing damage. Personally I like it there for that reason. Oil temp, oil pressure, and head temp. I think they are critical to stop you from hurting something. But it is sometimes better to just not know...
that said, putting the sender in isn't fun. The threads in the block are unobtanium for a fitting these days. |
| Superhawk996 |
Mar 15 2022, 03:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
The threads in the block are unobtanium for a fitting these days. Not sure what is meant here. Threads in block are no mystery. M10x1.0 Metric pipe taper. However, a 1/8" NPT will also work. I know people get mad and say that 1/8" NPT isn't the same as M10 x 1.0 taper. They are correct. However, are so close as to be interchangeable in a pinch. Sort of like a 19mm socket and a 3/4" socket either will work. Either way, any decent hose fabrication shop can obtain and build to your specification. The key being the fitting has to be a pipe taper. |
| emerygt350 |
Mar 15 2022, 04:31 PM
The threads in the block are unobtanium for a fitting these days. Not sure what is meant here. Threads in block are no mystery. M10x1.0 Metric pipe taper. However, a 1/8" NPT will also work. I know people get mad and say that 1/8" NPT isn't the same as M10 x 1.0 taper. They are correct. However, are so close as to be interchangeable in a pinch. Sort of like a 19mm socket and a 3/4" socket either will work. Either way, any decent hose fabrication shop can obtain and build to your specification. The key being the fitting has to be a pipe taper. When my hose broke I bought a whole selection off amazon (nobody around here, even the shops that specialize in fittings, can get m10x1 pipe thread to 1/8NPT needed to fit a hose). None of the amazon versions were correct. Eventually I sucked it up and forced the closest one I could get and used copper tubing to the sender. |
| brant |
Mar 16 2022, 08:37 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
The threads in the block are unobtanium for a fitting these days. Not sure what is meant here. Threads in block are no mystery. M10x1.0 Metric pipe taper. However, a 1/8" NPT will also work. I know people get mad and say that 1/8" NPT isn't the same as M10 x 1.0 taper. They are correct. However, are so close as to be interchangeable in a pinch. Sort of like a 19mm socket and a 3/4" socket either will work. Either way, any decent hose fabrication shop can obtain and build to your specification. The key being the fitting has to be a pipe taper. When my hose broke I bought a whole selection off amazon (nobody around here, even the shops that specialize in fittings, can get m10x1 pipe thread to 1/8NPT needed to fit a hose). None of the amazon versions were correct. Eventually I sucked it up and forced the closest one I could get and used copper tubing to the sender. I found one on the internet a few years ago not sure why they would dry up.. maybe supply problems? check belmetric and the other big suppliers if you don't want to seek out a metric one... go to the flaps and buy a replacement grease gun hose... which is the correct SAE size or buy an paint gun hose... also the same SAE size. brant |
DC_neun_vierzehn Oil pressure gauge benefits Mar 15 2022, 09:31 AM
GregAmy IMO, nothing specific to 914s, just a driver/owner... Mar 15 2022, 09:41 AM
Superhawk996
I'm perfectly happy with the idiot light tha... Mar 15 2022, 09:47 AM
Mark Henry
[quote name='GregAmy' post='2988311' date='Mar 15... Mar 16 2022, 06:24 AM
windforfun
IMO, nothing specific to 914s, just a driver/owne... Mar 15 2022, 07:12 PM
windforfun
Superhawk996
When my hose broke I bought a whole selection off... Mar 15 2022, 06:00 PM
Jonathan Livesay
The threads in the block are unobtanium for a fi... Mar 15 2022, 07:08 PM
Steve I agree.. Might be more useful on a six. I was t... Mar 15 2022, 12:58 PM
Superhawk996 Sorry - apology owed to OP for getting so far off ... Mar 15 2022, 06:03 PM
GregAmy And if you want to improve the visibility of that ... Mar 16 2022, 08:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:29 PM |
