| TRS63 |
Mar 17 2022, 10:24 AM
Member ![]() ![]() Group: Members Posts: 326 Joined: 14-September 20 From: Germany - Stuttgart Member No.: 24,690 Region Association: Europe
Hello all,
slowly I am coming to the point of thinking about putting the engine back..but now is also the point for some preventive maintenance on it! The start: -engine is the original 1,8l with L-Jet -it worked all good until I stopped it and removed the engine for rust repair last August -fuel pump is approx 2 years old What is planned: -oil change of course -oil+air filter of course -all fuel lines, engine side but also the ones in the tunnel (stainless steel ones) and under the tank I don't want to invest so much as it was a good running unit and I don't want to overdo. But I want a reliable car and more than that as much safety as possible (especially fire-risks). I am also unsure what the future will be : carbs or modern FI with ITBs ? I am missing the clean look and admission sound with the current setup. So no unnecessary invest in the L-Jet. What is sure: I will stay in the future with a 4 cylinders (but probably a bigger one) for weight reasons. -->do I need to change injectors sealings ? If yes, which ones? -->something else ? Thanks for the inputs Antoine |
| bkrantz |
Mar 17 2022, 09:44 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Any indication of pushrod tube seal oil leaks? That's another job that is low cost and much, much easier with the engine out.
TRS63 "while I'm there".. Mar 17 2022, 10:24 AM
Shivers How many miles on the engine? If older, and it was... Mar 17 2022, 10:48 AM
TRS63 I don't know the mileage..really low the last ... Mar 17 2022, 10:58 AM
914Mels The small injector seals that fit into the intake ... Mar 17 2022, 08:15 PM
wonkipop as per @Shivers .
do those end seals with the en... Mar 17 2022, 08:57 PM
SKL1 Oh heck, while the engine is out, just add a new ... Mar 17 2022, 09:54 PM
930cabman What is there NOT to change "while you are in... Mar 18 2022, 05:00 AM
BK911 Rubber brake lines. Rears much easier with engine... Mar 18 2022, 06:56 AM
Eric_Shea
Rubber brake lines. Rears much easier with engin... Mar 18 2022, 01:44 PM
TRS63 Thanks so much for all your inputs!!
Brak... Mar 20 2022, 02:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:47 PM |
