| TRS63 |
Mar 17 2022, 10:24 AM
Member ![]() ![]() Group: Members Posts: 326 Joined: 14-September 20 From: Germany - Stuttgart Member No.: 24,690 Region Association: Europe
Hello all,
slowly I am coming to the point of thinking about putting the engine back..but now is also the point for some preventive maintenance on it! The start: -engine is the original 1,8l with L-Jet -it worked all good until I stopped it and removed the engine for rust repair last August -fuel pump is approx 2 years old What is planned: -oil change of course -oil+air filter of course -all fuel lines, engine side but also the ones in the tunnel (stainless steel ones) and under the tank I don't want to invest so much as it was a good running unit and I don't want to overdo. But I want a reliable car and more than that as much safety as possible (especially fire-risks). I am also unsure what the future will be : carbs or modern FI with ITBs ? I am missing the clean look and admission sound with the current setup. So no unnecessary invest in the L-Jet. What is sure: I will stay in the future with a 4 cylinders (but probably a bigger one) for weight reasons. -->do I need to change injectors sealings ? If yes, which ones? -->something else ? Thanks for the inputs Antoine |
| TRS63 |
Mar 20 2022, 02:29 PM
Thanks so much for all your inputs!!
Brake lines are already planned, as is the rubber around the engine. I was unsure about the engine itself (IMG:style_emoticons/default/smile.gif) I will look for those end seals, thanks! Antoine |
TRS63 "while I'm there".. Mar 17 2022, 10:24 AM
Shivers How many miles on the engine? If older, and it was... Mar 17 2022, 10:48 AM
TRS63 I don't know the mileage..really low the last ... Mar 17 2022, 10:58 AM
914Mels The small injector seals that fit into the intake ... Mar 17 2022, 08:15 PM
wonkipop as per @Shivers .
do those end seals with the en... Mar 17 2022, 08:57 PM
bkrantz Any indication of pushrod tube seal oil leaks? Th... Mar 17 2022, 09:44 PM
SKL1 Oh heck, while the engine is out, just add a new ... Mar 17 2022, 09:54 PM
930cabman What is there NOT to change "while you are in... Mar 18 2022, 05:00 AM
BK911 Rubber brake lines. Rears much easier with engine... Mar 18 2022, 06:56 AM
Eric_Shea
Rubber brake lines. Rears much easier with engin... Mar 18 2022, 01:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:30 AM |
