Brake Pressure regulator relocation, Need help with a dimention |
pencap914 |
Mar 26 2022, 06:39 PM
Member Group: Members Posts: 75 Joined: 16-April 06 Member No.: 5,872 Region Association: Northern California |
I'm relocating the rear brake pressure regulator valve to where it resides on an early 914 (1970-1973) since I installed the Maddog OEM style motor mount.
Does anyone have this dimension handy? Just want to know how low to have the top mounting bolt from the bottom of the horizontal sheet metal where the air shroud has the rubber seal. (See picture below, and ignore the wonky firewall repair... it wasn't me!) |
Superhawk996 |
Mar 26 2022, 07:13 PM
914 Guru Group: Members Posts: 5,900 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
43 mm from underside of the ledge to the center of the top hole. If you look under the ledge, you'll see a small flange under there. I measured from the underside of that little weld flange. Measured with tape measure resting right up against that stiffening rib you drew the arrows along.
I can't get an accurate measurement to the point you want by eye because there is going to be variation in the height of your shelf depending on if it is deflected at all over the years. There will also be a chance of height variation when projecting that point you want back to the firewall unless done with a straight edge and trying to keep it square. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:51 PM |
