1.7L carb fuel supply |
Tewfiks |
Mar 29 2022, 10:51 AM
Newbie Group: Members Posts: 5 Joined: 23-March 22 From: Florida Member No.: 26,416 Region Association: South East States |
Hello All,
this is my first of many questions as I embark on getting my 1973 914 back on the road. I purchased the car from a friend who said it ran great before his voltage regulator began giving him issues. I was storing the car for several years for him before buying it. I know would like to see it running again. It is a 73 1.7L with dual webers. The fuel tank was cleaned and out of the car. I went to reinstall the tank and replace the rubber lines when I noticed that both the fuel outlets on the bottom of the tank were capped off . I can not locate fuel pipe for the line to attach to the tank. I have also been told that I only need the supply line and can cap off the return line of the original fuel injection set up. Any advice or words of wisdom would be greatly appreciated. Where can I source the fuel pipes and nuts? Auto Atlanta does not have them currently. Thanks |
SirAndy |
Mar 29 2022, 02:02 PM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If you are in there anyways, although technically not needed, carbs do benefit from having a working return line.
It helps keeping the fuel in the bowls cooler and prevents heat soak and possible hot start issues. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 12:32 AM |
