1.7L carb fuel supply |
Tewfiks |
Mar 29 2022, 10:51 AM
Newbie Group: Members Posts: 5 Joined: 23-March 22 From: Florida Member No.: 26,416 Region Association: South East States |
Hello All,
this is my first of many questions as I embark on getting my 1973 914 back on the road. I purchased the car from a friend who said it ran great before his voltage regulator began giving him issues. I was storing the car for several years for him before buying it. I know would like to see it running again. It is a 73 1.7L with dual webers. The fuel tank was cleaned and out of the car. I went to reinstall the tank and replace the rubber lines when I noticed that both the fuel outlets on the bottom of the tank were capped off . I can not locate fuel pipe for the line to attach to the tank. I have also been told that I only need the supply line and can cap off the return line of the original fuel injection set up. Any advice or words of wisdom would be greatly appreciated. Where can I source the fuel pipes and nuts? Auto Atlanta does not have them currently. Thanks |
jasons |
Mar 30 2022, 12:05 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
How do you plumb the return? Fuel tank feed to carb 1 (through a pump), 2 way banjo to carb 2 using another 2 way banjo for the return?
Front yard mechanic |
Mar 30 2022, 08:04 PM
Senior Member Group: Members Posts: 1,174 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
How do you plumb the return? Fuel tank feed to carb 1 (through a pump), 2 way banjo to carb 2 using another 2 way banjo for the return? (IMG:style_emoticons/default/popcorn[1].gif) |
jasons |
Mar 30 2022, 08:24 PM
How do you plumb the return? Fuel tank feed to carb 1 (through a pump), 2 way banjo to carb 2 using another 2 way banjo for the return? (IMG:style_emoticons/default/popcorn[1].gif) Right? (IMG:style_emoticons/default/drunk.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 11:41 PM |
