| boxster914 |
Apr 12 2022, 11:18 AM
Member ![]() ![]() Group: Members Posts: 77 Joined: 17-September 20 From: NC, USA Member No.: 24,700 Region Association: South East States |
Hi everyone
My perfectly running 71 914 1.7 D-jet has deteriorated rapidly this past week. Early in the week I noticed what felt like a power drop out during a drive. It was very slight and only happened once and I wasn't sure I didn't cause it by unconciously lifting off the gas. The next drive it happened a few times and was more pronounced. It was then that I knew this wasn't an imagined problem. On the third drive it was like a bucking bronco, surging and stopping and the engine cut out a few times. It was undriveable. Today it will start but won't run. The engine cuts out when I try to rev it and the red light comes on. I've done some searching here but haven't been able to draw any conclusions or come up with an actionable strategy to diagnose the problem. I'm seeing people trace it to spark plug wires, air fuel ratios and bad distributors. Is there a step-by-step process that you can recommend for me to get to the cause of this? (I'm a newb so I probably will need help with abbreviations like AFR, TPS, etc.) Here is a video of it's rough idle yesterday when it was still running. https://youtu.be/n61CP6O8UgM |
| BillJ |
Apr 13 2022, 09:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
This exact behavior happened twice in my 75. Went through two filters before simply changing out the tank. Never had another issue.
Changing just the filter may solve though. |
boxster914 "Trailer-hitching" bucking problem Apr 12 2022, 11:18 AM
krazykonrad I had a very similar issue. After much poking abou... Apr 12 2022, 11:49 AM
BillJ Start with fuel filter? Sounds like a progressive... Apr 12 2022, 12:18 PM
Root_Werks
Start with fuel filter? Sounds like a progressiv... Apr 12 2022, 01:05 PM
boxster914
Start with fuel filter? Sounds like a progressi... Apr 12 2022, 07:52 PM
930cabman
Start with fuel filter? Sounds like a progressiv... Apr 12 2022, 01:58 PM
Lockwodo
Hi everyone
My perfectly running 71 914 1.7 D-je... Apr 12 2022, 12:32 PM
ClayPerrine "and the red light comes on."
Which red... Apr 12 2022, 01:00 PM
Lockwodo
Which re... Apr 12 2022, 01:30 PM
mepstein Also check all the grounds. Easy to do and while y... Apr 12 2022, 01:49 PM
Lockwodo
Also check all the grounds. Easy to do and while ... Apr 12 2022, 01:53 PM
BillJ Everything he described could be due to a clogged ... Apr 12 2022, 02:51 PM
boxster914 You guys are awesome!
My weekend of detective... Apr 12 2022, 03:48 PM
Lockwodo
My weekend of detectiv... Apr 12 2022, 05:06 PM
boxster914
My weekend of detecti... Apr 12 2022, 07:43 PM
mgphoto Clean and check the FI points in the base of the d... Apr 12 2022, 03:49 PM
mgphoto
Clean and check the FI points in the base of the ... May 1 2022, 10:06 AM
Lockwodo
Clean and check the FI points in the base of the... May 1 2022, 10:53 AM
mgphoto
[quote name='mgphoto' post='2998850' date='May 1 ... May 1 2022, 02:02 PM
Lockwodo
[quote name='mgphoto' post='2994793' date='Apr 12... May 24 2022, 07:17 AM
Ansbacher Check all the wire connections to the coil. Make ... Apr 12 2022, 05:49 PM
wonkipop thanks for putting up that video.
its hunting as ... Apr 12 2022, 06:41 PM
Lockwodo
its hunting as... Apr 12 2022, 07:24 PM
wonkipop
its hunting a... Apr 12 2022, 07:52 PM
r_towle https://members.rennlist.com/pbanders/DJetParts.ht... Apr 12 2022, 06:46 PM
emerygt350 If it approached this point gradually, start with ... Apr 12 2022, 07:09 PM
wonkipop @[url=http://www.914world.com/bbs2/index.php?showu... Apr 13 2022, 12:18 AM
Lockwodo Thanks Boxster914, very helpful to have the manual... Apr 13 2022, 08:03 AM
wonkipop
Thanks Boxster914, very helpful to have the manua... Apr 13 2022, 08:51 AM
Root_Werks
This exact behavior happened twice in my 75. Wen... Apr 13 2022, 09:47 AM
Jamie
This exact behavior happened twice in my 75. We... Apr 13 2022, 09:58 AM
Lockwodo
This exact behavior happened twice in my 75. Wen... Apr 13 2022, 11:16 AM
rhodyguy Could the tank well for the supply be filled with ... Apr 13 2022, 09:46 AM
DRPHIL914 lots of good advice here already, if the fuel pre... Apr 13 2022, 11:56 AM
emerygt350
lots of good advice here already, if the fuel pr... Apr 13 2022, 02:48 PM
Lockwodo
lots of good advice here already, if the fuel pr... Apr 14 2022, 06:27 PM
DRPHIL914
lots of good advice here already, if the fuel p... Apr 18 2022, 08:09 AM
BillJ Sounds like fuel delivery to the rail is fine. Go... Apr 13 2022, 12:30 PM
wonkipop ok
fuels good.
ignition system next.
check the ... Apr 13 2022, 03:32 PM
Lockwodo Yes indeed.
Note to boxster914: I hope my car ... Apr 13 2022, 06:28 PM
boxster914 Thank you all for your input (and @lockwodo I ap... Apr 14 2022, 08:28 AM
Dave_Darling On a D-Jet car, the hesitation that happens when t... Apr 14 2022, 01:31 PM
boxster914 OK so I have some results to report on.
I changed... Apr 17 2022, 08:39 PM
wonkipop if its anything like a L jet, its the vac retard l... Apr 17 2022, 09:17 PM
wonkipop i was just reading back through your thread @boxs... Apr 17 2022, 10:04 PM
emerygt350 What year is it again? Is that an egr? Apr 18 2022, 05:04 AM
rjames The vacuum hose goes to the retard port of the thr... Apr 18 2022, 07:44 AM
emerygt350
The vacuum hose goes to the retard port of the th... Apr 18 2022, 01:22 PM
wonkipop
The vacuum hose goes to the retard port of the t... Apr 18 2022, 06:01 PM
ClayPerrine Have you checked the little ground wire that is in... Apr 18 2022, 01:26 PM
Garland :wttc: Apr 18 2022, 04:05 PM
Lockwodo Clay: I'll check the ground wire in the disty... Apr 18 2022, 06:41 PM
boxster914 I have more data to report on this issue.
The car... Apr 28 2022, 05:18 PM
Lockwodo
The ca... Apr 29 2022, 06:57 AM
wonkipop
The ca... Apr 29 2022, 08:24 PM
emerygt350 Interesting! All kinds of badness can result ... Apr 29 2022, 04:25 AM
ChrisFoley The clamp on the positive cable appears pretty tir... Apr 29 2022, 04:43 AM
boxster914 Yes @wonkipop the wires did seem tight to me. I ... Apr 30 2022, 04:01 PM
wonkipop
Yes [b]@[url=http://www.914world.com/bbs2/index.... Apr 30 2022, 06:08 PM
Lockwodo I've come to believe that battery cables shoul... Apr 30 2022, 05:41 PM
boxster914 Thank you all for your input.
Thank you @lockwod... May 1 2022, 08:26 AM
Lockwodo
Thank you [b]@[ur... May 1 2022, 09:36 AM
ChrisFoley I remember having trouble with old Crane optical s... May 2 2022, 04:12 AM
mgphoto Glad it worked out. May 24 2022, 04:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 08:00 AM |
