Tail light lens seal, where does it go? |
vitamin914 |
Apr 22 2022, 08:41 PM
Member Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada |
I need some guidance with installing the rubber cord seal from 914Rubber on the tail lights.
The lenses and reflector housings are replacements from AA. The OEMs are too far gone with no reflector chrome and corrosion in the sockets. It seems the contour of the lens isn't a perfect match to reflector housing (even on the old OEM housing). There is a gap mid way at the top (see first photo). The gap sort of disappears if there is no rubber cord when the lens and housing nest together. Adding the rubber cord makes it worse as the lens does not seat as deeply. This also raises the question... Where does the rubber cord go? Does it go in the housing or does it go in the lens? (last two photos) I really want to stay away from using RTV silicone if I ever need to change a bulb. |
Shivers |
Apr 23 2022, 08:54 AM
Senior Member Group: Members Posts: 2,420 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
My original lens had the cord stuck in the lens groove. Canada weather, maybe use a heat lamp bulb, keep it a safe distance away and add a clamp, tighten it a little everyday at that point and leave it for a while. It can be 120+ here in the summer and heat does work.
Lo-Fi Version | Time is now: 7th June 2024 - 02:51 AM |
