Tail light lens seal, where does it go? |
vitamin914 |
Apr 22 2022, 08:41 PM
Member Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada |
I need some guidance with installing the rubber cord seal from 914Rubber on the tail lights.
The lenses and reflector housings are replacements from AA. The OEMs are too far gone with no reflector chrome and corrosion in the sockets. It seems the contour of the lens isn't a perfect match to reflector housing (even on the old OEM housing). There is a gap mid way at the top (see first photo). The gap sort of disappears if there is no rubber cord when the lens and housing nest together. Adding the rubber cord makes it worse as the lens does not seat as deeply. This also raises the question... Where does the rubber cord go? Does it go in the housing or does it go in the lens? (last two photos) I really want to stay away from using RTV silicone if I ever need to change a bulb. |
wonkipop |
Apr 23 2022, 08:26 PM
Advanced Member Group: Members Posts: 4,367 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
@vitamin914
ouch i pulled out the orig hella us units i have had for a long time. not kinked as per aftermarket. these things must be hard to make -maybe deform due to manufacturing processes and stress after being released from casting moulds. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:11 AM |
