> Stainless Steel Fuel Lines, How to install them in your 914
ClayPerrine
post Nov 28 2004, 09:13 AM
Here's the link........
Stainless steel fuel line installation.
I will be updating it as I find time to get back in the garage and finish the job! (IMG:style_emoticons/default/smile.gif)
TRS63
post Apr 25 2022, 05:42 AM
Region Association: Europe
I am taking this old thread up as I am having trouble pushing the lines through the front grommet (between passenger cabin and tank area). Is it recommended to remove the grommet from its position, install the lines through it and then put it back with the lines inside it ?
Thanks a lot
Antoine
Superhawk996
post Apr 25 2022, 06:16 AM
QUOTE(TRS63 @ Apr 25 2022, 07:42 AM) *
Thanks a lot
Antoine
Pull the grommets (both front and rear) from body sheet metal 1st.
Get lines routed out the big hole in front sheet metal under the gas tank.
Now put some glycerin on the fuel line tubes. Slide the front grommet onto the tubes.
A dab of glycerin on the retaining lip of the grommet.
Push the front grommet into body sheetmetal. Seat bottom side you can't see 1st. Then push in the top side -- use wide lip plastic trim tool (could use screwdriver but be careful due to small / sharp edge) to tuck the retaining lip in and seated to the body, being careful not to rip the grommet.
Same sort of process for the small circular rear firewall grommets but takes longer and a little more finesse to get them seated.
Just installed the grommets on my own project about a week ago and used this process.
@TRS63
ClayPerrine   Stainless Steel Fuel Lines   Nov 28 2004, 09:13 AM
Jeroen   Nice write up and good pics!   Nov 28 2004, 11:17 AM
ThinAir914   :worship: Cool!   Nov 28 2004, 11:18 AM
drew365   New fuel lines are moving to the top of my priorit...   Nov 28 2004, 11:51 AM
restore2seater   "Thanks for the write up but the pics didn't l...   Nov 28 2004, 12:27 PM
a9146luvr   Excellent post, awaiting the finish with required ...   Nov 28 2004, 12:55 PM
Carrera916   That looks real good and my only regret was that I...   Nov 28 2004, 02:43 PM
Jeroen   I've converted Clay's page into a club-pag...   Nov 28 2004, 02:52 PM
ClayPerrine     Nov 29 2004, 02:30 PM
Dr Evil   I did the one off of the bird board tech section w...   Nov 29 2004, 02:39 PM
Britain Smith   What size lines do ya recommend running? I was th...   Nov 29 2004, 03:06 PM
Qarl   Can someone educate me on bending lines? How do y...   Nov 29 2004, 03:20 PM
ClayPerrine   I never explored the idea of using Braided SS line...   Nov 29 2004, 03:27 PM
Mueller   not that I like the idea too much for fuel lines.....   Nov 29 2004, 03:30 PM
Steve   I also did the one off the bird site for my 3.2 co...   Nov 29 2004, 10:23 PM
bperry   Here's the link........ [url=http://www.per...   Jan 20 2016, 12:41 PM
Jeff Hail   Please don't use sand inside of tubes while be...   Jan 20 2016, 08:08 PM
TRS63   I am taking this old thread up as I am having trou...   Apr 25 2022, 05:42 AM
Superhawk996   I am taking this old thread up as I am having tro...   Apr 25 2022, 06:16 AM
mepstein   Put some lube on the line and it should slide thro...   Apr 25 2022, 06:06 AM
TRS63   Thanks guys! Looks like both method should wor...   Apr 25 2022, 06:35 AM
iankarr   Yep. A helper with lube makes the process a lot mo...   Apr 25 2022, 11:14 AM
TRS63   Yep. A helper with lube makes the process a lot m...   Apr 25 2022, 11:56 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:38 PM
