911 606 135 00 Pressure Sender, Connector and threading? |
FlacaProductions |
May 6 2022, 06:45 AM
Senior Member Group: Members Posts: 1,616 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Greetings,
Adding a beautiful triple gauge built by John Bell. The pressure part of the program uses sender 911 606 135 00 from an 84-89 911. I'm putting it in a 42 draft design block so that I can also use the stock idiot light sender as well. Anyone know the threading? I'm hoping it's M10? Also - what wiring connector? doesn't look like a threaded shaft and nut to me...thanks! |
arbitrary |
May 6 2022, 08:22 AM
Member Group: Members Posts: 81 Joined: 25-April 21 From: UK Member No.: 25,475 Region Association: None |
Greetings, Adding a beautiful triple gauge built by John Bell. The pressure part of the program uses sender 911 606 135 00 from an 84-89 911. I'm putting it in a 42 draft design block so that I can also use the stock idiot light sender as well. Anyone know the threading? I'm hoping it's M10? Also - what wiring connector? doesn't look like a threaded shaft and nut to me...thanks! I think people have used a female bullet connector in lieu of the NLA factory parts. |
Lo-Fi Version | Time is now: 9th June 2024 - 12:03 PM |
