> Why did my rockers break? 6 cylinder
David Stowers
post May 16 2022, 09:32 AM
Hi all,
All 3 exhaust rockers broke on one side (4,5,6) when I started my engine for the first rime after cam and rocker re grind.
What’s the likely cause here folks?
Thank you
fixer34
post May 16 2022, 05:44 PM
Assuming the pistons hit the exhaust valves while still partially open when at top of stroke. Cam timing needs to be off quite a bit (delayed) if it hard hard enough to snap the rocker arms. By any chance did you/someone forget to insert the locking pin into the cam gear. Tighten the cam nut and it will rotate by hand and everything looks good. Under power, the cam gear slips and that's it...
If you are real lucky it didn't trash the valves or pistons.
David Stowers   Why did my rockers break? 6 cylinder   May 16 2022, 09:32 AM
Superhawk996   Lots of possibilities. None of them good. I...   May 16 2022, 09:38 AM
David Stowers   Lots of possibilities. None of them good. I...   May 16 2022, 09:42 AM
nditiz1   At what point did they break? Did the cam timing ...   May 16 2022, 10:02 AM
brant   I've been told in the past that some year of T...   May 16 2022, 10:52 AM
porschetub   I've been told in the past that some year of ...   May 16 2022, 07:03 PM
rgalla9146   :agree: all of the above. Consider yourself a...   May 16 2022, 04:02 PM
mb911   Ugh what a sick feeling. My guess is wrong cam tim...   May 16 2022, 04:31 PM
euro911   :agree:   May 16 2022, 05:04 PM
fixer34   Assuming the pistons hit the exhaust valves while ...   May 16 2022, 05:44 PM
r_towle   The valve hit the piston. Either valve timing or c...   May 16 2022, 06:07 PM
sixnotfour   Bad News, you bumped cast pistons....   May 16 2022, 09:07 PM
mepstein   cam timed 180 degrees out? It happens.   May 16 2022, 09:19 PM
sixnotfour   cam timed 180 degrees out? It happens. :beer2:   May 16 2022, 09:44 PM
Retroracer   Like @FIxer34 suggested, missing or sheared cam ...   May 17 2022, 07:18 AM
burton73   Cam timing on my 6 This is not so easy and you ...   May 17 2022, 10:43 AM
sixnotfour   Many shops have the tools ,but have done 180 out a...   May 17 2022, 08:15 PM
Luke M   Have you checked the valve to piston clearance ? T...   May 18 2022, 08:13 AM
ClayPerrine   I have lots of experience with setting the cam tim...   May 18 2022, 11:04 AM
Jake Raby   I have lots of experience with setting the cam ti...   May 18 2022, 08:01 PM
- Lo-Fi Version Time is now: 23rd September 2025 - 02:29 AM
