> Why did my rockers break? 6 cylinder
David Stowers
post May 16 2022, 09:32 AM
Hi all,
All 3 exhaust rockers broke on one side (4,5,6) when I started my engine for the first rime after cam and rocker re grind.
What’s the likely cause here folks?
Thank you
post May 16 2022, 09:19 PM
914-6 GT in waiting
cam timed 180 degrees out? It happens.
David Stowers   Why did my rockers break? 6 cylinder   May 16 2022, 09:32 AM
Superhawk996   Lots of possibilities. None of them good. I...   May 16 2022, 09:38 AM
David Stowers   Lots of possibilities. None of them good. I...   May 16 2022, 09:42 AM
nditiz1   At what point did they break? Did the cam timing ...   May 16 2022, 10:02 AM
brant   I've been told in the past that some year of T...   May 16 2022, 10:52 AM
porschetub   I've been told in the past that some year of ...   May 16 2022, 07:03 PM
rgalla9146   :agree: all of the above. Consider yourself a...   May 16 2022, 04:02 PM
mb911   Ugh what a sick feeling. My guess is wrong cam tim...   May 16 2022, 04:31 PM
euro911   :agree:   May 16 2022, 05:04 PM
fixer34   Assuming the pistons hit the exhaust valves while ...   May 16 2022, 05:44 PM
r_towle   The valve hit the piston. Either valve timing or c...   May 16 2022, 06:07 PM
sixnotfour   Bad News, you bumped cast pistons....   May 16 2022, 09:07 PM
mepstein   cam timed 180 degrees out? It happens.   May 16 2022, 09:19 PM
sixnotfour   cam timed 180 degrees out? It happens. :beer2:   May 16 2022, 09:44 PM
Retroracer   Like @FIxer34 suggested, missing or sheared cam ...   May 17 2022, 07:18 AM
burton73   Cam timing on my 6 This is not so easy and you ...   May 17 2022, 10:43 AM
sixnotfour   Many shops have the tools ,but have done 180 out a...   May 17 2022, 08:15 PM
Luke M   Have you checked the valve to piston clearance ? T...   May 18 2022, 08:13 AM
ClayPerrine   I have lots of experience with setting the cam tim...   May 18 2022, 11:04 AM
Jake Raby   I have lots of experience with setting the cam ti...   May 18 2022, 08:01 PM
- Lo-Fi Version Time is now: 23rd September 2025 - 02:28 AM
