| nditiz1 |
May 18 2022, 07:16 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,272 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region
So I have posted on this before and am still confused.
How much rear suspension travel should there be on a 6? 74 chassis 2.4L engine Springs appear to be 100 lb ones Shocks are Bilstein C clip at lowest setting No rear sway bar With this setup the car sat low - cool, but there was no rear suspension travel. It was stiff back there. I push down and there is no give. Now, maybe that is how it is supposed to be?? I remember my 4 having a little bit of rebound, but that was with 200lb less back there. So I am in the process of clicking up two spots on the Bilsteins to get some rebound back. Seems counter intuitive though. If I compress the spring more it will be more stiff. My thinking here is that there is now travel with two clicks up since before when down on the ground the spring and shock were already compressed so no suspension travel was left on the console and or the shock. Thoughts? |
Shivers I'm just wondering, with the extra weight, is ... May 18 2022, 07:23 AM
mepstein Changing the height of the shock won’t change th... May 18 2022, 07:46 AM
Superhawk996
Changing the height of the shock won’t change t... May 18 2022, 08:50 AM
nditiz1 So let's go with the rear should have some giv... May 18 2022, 08:05 AM
Superhawk996 @nditiz1
May 18 2022, 08:58 AM
Mark Henry :agree:
100lb springs and new won't have muc... May 18 2022, 09:12 AM
nditiz1 Ahhhhhh, ok so the lack of compression in the rear... May 18 2022, 09:29 AM
Superhawk996
Ahhhhhh, ok so the lack of compression in the rea... May 18 2022, 09:35 AM
nditiz1
[quote name='nditiz1' post='3002549' date='May 18... May 18 2022, 10:22 AM
brant The cars actually handle best with a rake
It is be... May 18 2022, 09:32 AM
Superhawk996
It is b... May 18 2022, 09:36 AM
Cairo94507 I have 140 pound springs in my car and it does not... May 18 2022, 09:33 AM
Superhawk996 For simplicity sake, let's say the motion rati... May 18 2022, 11:28 AM
Mark Henry For a street car lowered about the max before bump... May 18 2022, 12:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 07:27 AM |
