> 6 rear suspension travel
nditiz1
post May 18 2022, 07:16 AM
So I have posted on this before and am still confused.
How much rear suspension travel should there be on a 6?
74 chassis
2.4L engine
Springs appear to be 100 lb ones
Shocks are Bilstein C clip at lowest setting
No rear sway bar
With this setup the car sat low - cool, but there was no rear suspension travel. It was stiff back there. I push down and there is no give. Now, maybe that is how it is supposed to be?? I remember my 4 having a little bit of rebound, but that was with 200lb less back there.
So I am in the process of clicking up two spots on the Bilsteins to get some rebound back. Seems counter intuitive though. If I compress the spring more it will be more stiff. My thinking here is that there is now travel with two clicks up since before when down on the ground the spring and shock were already compressed so no suspension travel was left on the console and or the shock. Thoughts?
nditiz1
post May 18 2022, 09:29 AM
Ahhhhhh, ok so the lack of compression in the rear is:
Common per Mark
and
Could also be due to %100 Sag
Now, by clicking up 2 spots on the Bilsteins I will in theory gain some compression due to Sag being at 75% which will also increase my ride height hopefully not to a "raked" look.
Superhawk996
post May 18 2022, 09:35 AM
QUOTE(nditiz1 @ May 18 2022, 11:29 AM) *
Common per Mark
and
I suspect you're looking at 140 lbs/in springs to get the look you want and to sill have sufficient compression travel.
You don't want to have the damper having used up 75% of it's potential travel at curb height.
On street use, it is virtually impossible to get wheels in the air (i.e. to have run out of rebound travel). This is why you want to bias toward having more compression travel than rebound travel.
If I read your comment above correctly, it sounds like you're proposing the opposite.
- Lo-Fi Version Time is now: 2nd May 2026 - 07:27 AM
