> Bilstein Questions Did I screw the pooch?
cgnj
post May 19 2022, 09:11 PM
I have a Mid 80's 911 Boge strut housing part number 0 21 132 267. The threads are on the outside of the housing. I ordered B6 34-001127. It came with 914 strut collar, that is meant to thread into ine inside off the housing. The part number etched into the collar is 836 816 E2. Is there a way to order the correct co;;ar for a 911 strut housing?. Should I have ordered a 911 strut? Does anyone have the Bilstein part number?
Are the bump stops required or a delete? The installation instructions say delete.
My rear coil over kit from Ground Control wants the bump stop cut down. Again is this a delete, cut in half? I had no bump stops in the rear. If required is is anyone aware of a supplier?
Thanks in advace,
Carlos
914Sixer
post May 20 2022, 06:06 AM
Yes you can get the correct collar from Bilstein. They will not be cheap.
Superhawk996
post May 20 2022, 06:45 AM
QUOTE(914Sixer @ May 20 2022, 08:06 AM) *
Maybe just sell the 914 struts here on forum and then buy proper 911 struts if the nut turns out to be cost prohibitive ? (IMG:style_emoticons/default/confused24.gif)
bump stops are internal to the Bilstien damper due to inverted damper construction.
- Lo-Fi Version Time is now: 15th November 2026 - 08:44 PM
