| ctc911ctc |
May 20 2022, 02:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
'74 914, all stock, near all original, 22k
As we all know getting the brake hose disconnected from the hard line can be a pistol on older cars, Heat always works, while doing the front end of the 914 (shocks and bushings) I am replacing the hoses - of course\ I needed to heat and started to torch (IMG:style_emoticons/default/blowtorch.gif) this connector when BANG! Turns out there was a very tight fit between the hose and connector, enough to hold pressure to an explosion point. Who Knew!?! Fortunately, I was wearing goggles. No, there were no blocks within the hose, this was not from what was IN the hose but between the hose and the connector. ![]() |
Van B My rubber brake lines are self lubricating so I do... May 20 2022, 02:43 PM
914_teener Never ever heat any part of a shock absorber
The ... May 21 2022, 02:35 PM
Tdskip
The... May 22 2022, 06:15 AM
GregAmy A line filled with clean brake fluid should not ha... May 22 2022, 07:03 AM
blabla914 you should probably also check the adjustment of t... May 22 2022, 02:19 PM
ctc911ctc **********Perhaps I was NOT clear.*********
The L... May 23 2022, 06:51 AM
914_teener Most brake fluids are flammable given enough heat.... May 23 2022, 08:31 AM
Shivers "This means it will easily burn compared to s... May 23 2022, 10:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 01:25 PM |
