> Can Too Much Oil Damage Your Motor?, Mechanic Added Too Much
windforfun
post May 20 2022, 02:33 PM
Ran it for about 1 hr prior to draining excess oil. The motor is a "73 1.7. Thanks.
Puebloswatcop
post May 21 2022, 02:21 PM
Most likely no significant problems. It will generally end up in the cylinders and make sludge. If it seems like it's not running smooth, pull the plugs and see if they are oil soaked. If they aren't and you're not showing signs of excessive blue smoke from the exhaust, you should be fine.
windforfun   Can Too Much Oil Damage Your Motor?   May 20 2022, 02:33 PM
Van B   Like a quart extra or to the top of the fill neck ...   May 20 2022, 02:44 PM
Shivers   I run a quarter quart or so high always   May 20 2022, 07:29 PM
Puebloswatcop   Most likely no significant problems. It will gene...   May 21 2022, 02:21 PM
Jake Raby   I see engines permanently damaged from too much oi...   May 22 2022, 07:26 AM
Sea Rooster   I see engines permanently damaged from too much o...   May 22 2022, 07:31 AM
emerygt350   Jake, what is your feeling on type of filter? I h...   May 22 2022, 07:40 AM
Superhawk996   I'm going to start a new religion based around...   May 22 2022, 07:47 AM
Lockwodo   I'm going to start a new religion based aroun...   May 22 2022, 09:46 AM
Van B   I'm going to start a new religion based arou...   May 22 2022, 02:09 PM
930cabman   I'm going to start a new religion based aroun...   May 23 2022, 05:43 AM
emerygt350   I do notice some different behavior as far as oil ...   May 22 2022, 08:09 AM
Superhawk996   I do notice some different behavior as far as oil...   May 22 2022, 08:35 AM
bbrock   Here's the thing. Keep you oil & filter...   May 22 2022, 03:42 PM
Big Len   Here's the thing. Keep you oil & filte...   May 22 2022, 04:03 PM
wonkipop   Here's the thing. Keep you oil & filte...   May 22 2022, 04:53 PM
bbrock   i would have thought synthetic oils are better a...   May 22 2022, 10:57 PM
Superhawk996   Still interested to hear why [b]@[url=http://ww...   May 23 2022, 06:25 AM
Superhawk996   i would have thought synthetic oils are better a...   May 23 2022, 06:52 AM
emerygt350   I just noticed the difference between a mobil1 fil...   May 22 2022, 10:40 AM
porschetub   I just noticed the difference between a mobil1 fi...   May 22 2022, 04:45 PM
emerygt350   That's a good point. I always use synthetic, ...   May 22 2022, 06:33 PM
Badinfluence1   Ran it for about 1 hr prior to draining excess oi...   May 23 2022, 12:51 AM
StarBear   Concur with Big Len’s comments. 20W50 high-phos ...   May 23 2022, 06:18 AM
930cabman   FWIW: I have been changing my oil (dino) every 3k...   May 23 2022, 06:51 AM
Van B   @[url=http://www.914world.com/bbs2/index.php?showu...   May 23 2022, 08:33 AM
Superhawk996   @[url=http://www.914world.com/bbs2/index.php?show...   May 23 2022, 09:39 AM
Van B   [quote name='Van B' post='3003624' date='May 23 2...   May 23 2022, 11:24 AM
Jamie   OK now, if considering a switch from dino to synth...   May 23 2022, 09:45 AM
emerygt350   OK now, if considering a switch from dino to synt...   May 23 2022, 12:29 PM
gandalf_025   Back, years ago…at a shop just outside Boston.. ...   May 23 2022, 10:43 AM
john ee quest   Ran it for about 1 hr prior to draining excess oi...   May 23 2022, 01:03 PM
vitamin914   I realize we are drifting off the too much oil que...   May 23 2022, 03:22 PM
porschetub   I realize we are drifting off the too much oil qu...   May 23 2022, 06:16 PM
vitamin914   Its gone from oil overfilling subject to a oil br...   May 24 2022, 05:56 AM
r_towle   For me, and my rare driving of any aircooled motor...   May 23 2022, 04:49 PM
Van B   @vitamin914 In addition to the better temperature...   May 23 2022, 05:39 PM
Jake Raby   VR-1 was changed due to LSPI in modern engines a c...   May 23 2022, 05:55 PM
Front yard mechanic   I watched the indi time trials and saw rpm's r...   May 24 2022, 06:29 AM
- Lo-Fi Version Time is now: 17th September 2026 - 06:47 AM
