> Heat and BANG, How did that happen?!?!?!?!?!?!
ctc911ctc
post May 20 2022, 02:35 PM
'74 914, all stock, near all original, 22k
As we all know getting the brake hose disconnected from the hard line can be a pistol on older cars,
Heat always works, while doing the front end of the 914 (shocks and bushings) I am replacing the hoses - of course\
I needed to heat and started to torch (IMG:style_emoticons/default/blowtorch.gif) this connector when BANG!
Turns out there was a very tight fit between the hose and connector, enough to hold pressure to an explosion point.
Who Knew!?! Fortunately, I was wearing goggles.
No, there were no blocks within the hose, this was not from what was IN the hose but between the hose and the connector.
914_teener
post May 21 2022, 02:35 PM
Never ever heat any part of a shock absorber
The brake lines are sealed like the shock absorbers. When you heated them the air inside exapanded with the obvious result and broke at the weakest area.
Same reasoning for any ensclosed assembly using heat with a combustable gas....not a good idea.
I used a pair of side cutters for the flexible lines and then dealt with the connection to the hard lines after with penetrant oil.
Glad you weren't hurt.
- Lo-Fi Version Time is now: 2nd May 2026 - 01:20 PM
