| windforfun |
May 20 2022, 02:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,115 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Ran it for about 1 hr prior to draining excess oil. The motor is a "73 1.7. Thanks.
| Superhawk996 |
May 22 2022, 07:47 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,058 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I'm going to start a new religion based around oil mysteries . . . (IMG:style_emoticons/default/huh.gif)
What type to use? What weight to use? What brand of oil is best to use? Check it at high tide or low tide? Check at full moon, Harvest Moon, or Blood Moon? What day of week to check it? What is the optimum oil temperature? What brand of filter is best? Sheesh! Just fill to the marks the OEM put on the dipstick and use the standard filter. Life doesn't need to be so hard. |
| Lockwodo |
May 22 2022, 09:46 AM
Member ![]() ![]() Group: Members Posts: 240 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California
I'm going to start a new religion based around oil mysteries . . . (IMG:style_emoticons/default/huh.gif) What type to use? What weight to use? What brand of oil is best to use? Check it at high tide or low tide? Check at full moon, Harvest Moon, or Blood Moon? What day of week to check it? What is the optimum oil temperature? What brand of filter is best? Sheesh! Just fill to the marks the OEM put on the dipstick and use the standard filter. Life doesn't need to be so hard. To which I would add, whether or not to use full synthetic? Synthetic oil decreases friction and increases horsepower, but some worry it'll result in oil leaks. What say you guys? |
windforfun Can Too Much Oil Damage Your Motor? May 20 2022, 02:33 PM
Van B Like a quart extra or to the top of the fill neck ... May 20 2022, 02:44 PM
Shivers I run a quarter quart or so high always May 20 2022, 07:29 PM
Puebloswatcop Most likely no significant problems. It will gene... May 21 2022, 02:21 PM
Jake Raby I see engines permanently damaged from too much oi... May 22 2022, 07:26 AM
Sea Rooster
I see engines permanently damaged from too much o... May 22 2022, 07:31 AM
emerygt350 Jake, what is your feeling on type of filter? I h... May 22 2022, 07:40 AM
Van B
I'm going to start a new religion based arou... May 22 2022, 02:09 PM
930cabman
I'm going to start a new religion based aroun... May 23 2022, 05:43 AM
emerygt350 I do notice some different behavior as far as oil ... May 22 2022, 08:09 AM
Superhawk996
I do notice some different behavior as far as oil... May 22 2022, 08:35 AM
bbrock
Here's the thing. Keep you oil & filter... May 22 2022, 03:42 PM
Big Len
Here's the thing. Keep you oil & filte... May 22 2022, 04:03 PM
wonkipop
Here's the thing. Keep you oil & filte... May 22 2022, 04:53 PM
bbrock
i would have thought synthetic oils are better a... May 22 2022, 10:57 PM
Superhawk996
Still interested to hear why [b]@[url=http://ww... May 23 2022, 06:25 AM
Superhawk996
i would have thought synthetic oils are better a... May 23 2022, 06:52 AM
emerygt350 I just noticed the difference between a mobil1 fil... May 22 2022, 10:40 AM
porschetub
I just noticed the difference between a mobil1 fi... May 22 2022, 04:45 PM
emerygt350 That's a good point. I always use synthetic, ... May 22 2022, 06:33 PM
Badinfluence1
Ran it for about 1 hr prior to draining excess oi... May 23 2022, 12:51 AM
StarBear Concur with Big Len’s comments. 20W50 high-phos ... May 23 2022, 06:18 AM
930cabman FWIW:
I have been changing my oil (dino) every 3k... May 23 2022, 06:51 AM
Van B @[url=http://www.914world.com/bbs2/index.php?showu... May 23 2022, 08:33 AM
Superhawk996
@[url=http://www.914world.com/bbs2/index.php?show... May 23 2022, 09:39 AM
Van B
[quote name='Van B' post='3003624' date='May 23 2... May 23 2022, 11:24 AM
Jamie OK now, if considering a switch from dino to synth... May 23 2022, 09:45 AM
emerygt350
OK now, if considering a switch from dino to synt... May 23 2022, 12:29 PM
gandalf_025 Back, years ago…at a shop just outside Boston..
... May 23 2022, 10:43 AM
john ee quest
Ran it for about 1 hr prior to draining excess oi... May 23 2022, 01:03 PM
vitamin914 I realize we are drifting off the too much oil que... May 23 2022, 03:22 PM
porschetub
I realize we are drifting off the too much oil qu... May 23 2022, 06:16 PM
vitamin914
Its gone from oil overfilling subject to a oil br... May 24 2022, 05:56 AM
r_towle For me, and my rare driving of any aircooled motor... May 23 2022, 04:49 PM
Van B @vitamin914
In addition to the better temperature... May 23 2022, 05:39 PM
Jake Raby VR-1 was changed due to LSPI in modern engines a c... May 23 2022, 05:55 PM
Front yard mechanic I watched the indi time trials and saw rpm's r... May 24 2022, 06:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 06:48 AM |
