| ctc911ctc |
May 20 2022, 02:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
'74 914, all stock, near all original, 22k
As we all know getting the brake hose disconnected from the hard line can be a pistol on older cars, Heat always works, while doing the front end of the 914 (shocks and bushings) I am replacing the hoses - of course\ I needed to heat and started to torch (IMG:style_emoticons/default/blowtorch.gif) this connector when BANG! Turns out there was a very tight fit between the hose and connector, enough to hold pressure to an explosion point. Who Knew!?! Fortunately, I was wearing goggles. No, there were no blocks within the hose, this was not from what was IN the hose but between the hose and the connector. ![]() |
| blabla914 |
May 22 2022, 02:19 PM
I like primer ![]() ![]() Group: Members Posts: 330 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None
you should probably also check the adjustment of the actuating rod on the master. there should be clearance. there is a spec in the book, don't recall what it is.
If the clearance isn't there then the master can be slightly depressed even when your foot is not on the brake pedal. this prevents pressure from bleeding off the system after every brake application as some of the heat of braking is transferrerred to the fluid. this can cause a big problem if not corrected before driving. As heat builds, the brakes will not release completely, which builds more heat. It's not good. I have to agree with advice above. If the lines are trash I usually cut them before I go for the torch. |
ctc911ctc Heat and BANG May 20 2022, 02:35 PM
Van B My rubber brake lines are self lubricating so I do... May 20 2022, 02:43 PM
914_teener Never ever heat any part of a shock absorber
The ... May 21 2022, 02:35 PM
Tdskip
The... May 22 2022, 06:15 AM
GregAmy A line filled with clean brake fluid should not ha... May 22 2022, 07:03 AM
ctc911ctc **********Perhaps I was NOT clear.*********
The L... May 23 2022, 06:51 AM
914_teener Most brake fluids are flammable given enough heat.... May 23 2022, 08:31 AM
Shivers "This means it will easily burn compared to s... May 23 2022, 10:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 01:24 PM |
