> Heat and BANG, How did that happen?!?!?!?!?!?!
ctc911ctc
post May 20 2022, 02:35 PM
'74 914, all stock, near all original, 22k
As we all know getting the brake hose disconnected from the hard line can be a pistol on older cars,
Heat always works, while doing the front end of the 914 (shocks and bushings) I am replacing the hoses - of course\
I needed to heat and started to torch (IMG:style_emoticons/default/blowtorch.gif) this connector when BANG!
Turns out there was a very tight fit between the hose and connector, enough to hold pressure to an explosion point.
Who Knew!?! Fortunately, I was wearing goggles.
No, there were no blocks within the hose, this was not from what was IN the hose but between the hose and the connector.
ctc911ctc
post May 23 2022, 06:51 AM
**********Perhaps I was NOT clear.*********
The Line (hard line and hose) was out of the car, on the bench....
There was NO Fluid in the hose nor in the Brake-Line. Both were clear end-to-end
The pressure was from the fluid that was in the fabric of the flexible brake hose which was trapped within the connector as in the picture. perhaps less than a drop or two of liquid.......if that.........
Thank you for all of the advice, but.........
The hose and the brake line were on a bench in a vice and I could not get them to release with a box wrench and penetrating oil,,,,so I then put a torch to it, and the hose popped!
I have never seen anything like it......so I thought i would share........just in case you have a similar situation.......
- Lo-Fi Version Time is now: 2nd May 2026 - 01:25 PM
