| windforfun |
May 20 2022, 02:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,115 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Ran it for about 1 hr prior to draining excess oil. The motor is a "73 1.7. Thanks.
| gandalf_025 |
May 23 2022, 10:43 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,532 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
Back, years ago…at a shop just outside Boston..
I saw at least 4, 930’s come in on flatbeds because the owners tried to cheap out and went to a quick oil change place.. Apparently the oil change places weren’t aware there were 3 oil drain plugs on 930’s.. They pulled the sump drain and then filled the car with like 13 quarts of oil.. Generally smoked a lot and made a big mess.. |
windforfun Can Too Much Oil Damage Your Motor? May 20 2022, 02:33 PM
Van B Like a quart extra or to the top of the fill neck ... May 20 2022, 02:44 PM
Shivers I run a quarter quart or so high always May 20 2022, 07:29 PM
Puebloswatcop Most likely no significant problems. It will gene... May 21 2022, 02:21 PM
Jake Raby I see engines permanently damaged from too much oi... May 22 2022, 07:26 AM
Sea Rooster
I see engines permanently damaged from too much o... May 22 2022, 07:31 AM
emerygt350 Jake, what is your feeling on type of filter? I h... May 22 2022, 07:40 AM
Superhawk996 I'm going to start a new religion based around... May 22 2022, 07:47 AM
Lockwodo
I'm going to start a new religion based aroun... May 22 2022, 09:46 AM
Van B
I'm going to start a new religion based arou... May 22 2022, 02:09 PM
930cabman
I'm going to start a new religion based aroun... May 23 2022, 05:43 AM
emerygt350 I do notice some different behavior as far as oil ... May 22 2022, 08:09 AM
Superhawk996
I do notice some different behavior as far as oil... May 22 2022, 08:35 AM
bbrock
Here's the thing. Keep you oil & filter... May 22 2022, 03:42 PM
Big Len
Here's the thing. Keep you oil & filte... May 22 2022, 04:03 PM
wonkipop
Here's the thing. Keep you oil & filte... May 22 2022, 04:53 PM
bbrock
i would have thought synthetic oils are better a... May 22 2022, 10:57 PM
Superhawk996
Still interested to hear why [b]@[url=http://ww... May 23 2022, 06:25 AM
Superhawk996
i would have thought synthetic oils are better a... May 23 2022, 06:52 AM
emerygt350 I just noticed the difference between a mobil1 fil... May 22 2022, 10:40 AM
porschetub
I just noticed the difference between a mobil1 fi... May 22 2022, 04:45 PM
emerygt350 That's a good point. I always use synthetic, ... May 22 2022, 06:33 PM
Badinfluence1
Ran it for about 1 hr prior to draining excess oi... May 23 2022, 12:51 AM
StarBear Concur with Big Len’s comments. 20W50 high-phos ... May 23 2022, 06:18 AM
930cabman FWIW:
I have been changing my oil (dino) every 3k... May 23 2022, 06:51 AM
Van B @[url=http://www.914world.com/bbs2/index.php?showu... May 23 2022, 08:33 AM
Superhawk996
@[url=http://www.914world.com/bbs2/index.php?show... May 23 2022, 09:39 AM
Van B
[quote name='Van B' post='3003624' date='May 23 2... May 23 2022, 11:24 AM
Jamie OK now, if considering a switch from dino to synth... May 23 2022, 09:45 AM
emerygt350
OK now, if considering a switch from dino to synt... May 23 2022, 12:29 PM
john ee quest
Ran it for about 1 hr prior to draining excess oi... May 23 2022, 01:03 PM
vitamin914 I realize we are drifting off the too much oil que... May 23 2022, 03:22 PM
porschetub
I realize we are drifting off the too much oil qu... May 23 2022, 06:16 PM
vitamin914
Its gone from oil overfilling subject to a oil br... May 24 2022, 05:56 AM
r_towle For me, and my rare driving of any aircooled motor... May 23 2022, 04:49 PM
Van B @vitamin914
In addition to the better temperature... May 23 2022, 05:39 PM
Jake Raby VR-1 was changed due to LSPI in modern engines a c... May 23 2022, 05:55 PM
Front yard mechanic I watched the indi time trials and saw rpm's r... May 24 2022, 06:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 06:49 AM |
