> Front End Rebuild - Questions, I should have powder coated EVERYTHING
ctc911ctc
post May 29 2022, 11:03 AM
'74 2.0 - around 25K, all original
Well, I thought this would go back together simply, not a chance - so I have a few questions.
1. TAB WASHER - does this do anything? If it is intended to do anything, why do I find pictures of this thing UN-LOADED, or the tabs bending downward NOT upward. I installed this with the tabs upward, took some pressure to get the cotter pin into the holes......this seems correct, any thoughts? Also, does it really do anything? Really? (IMG:style_emoticons/default/confused24.gif)
2. Threaded Pin - I tried to get this thing in and it does not fit. Looking at the picture I bought ball-joints for up to '72! HOWEVER, the ball joints I purchased on the BirdSite are specified to fit on a '74. They do fit. HOWEVER, the Threaded pin does not.
To make this MORE interesting, the AutoAtlanta website description details that their theaded pin is for '72 and later......... (IMG:style_emoticons/default/confused24.gif)
QUESTION: Do I buy an older theaded pin? Do I grind the marks on the one I have to make it fit? NOTE: there are two marks from where the pin is meeting the curve of the ball joint..... (IMG:style_emoticons/default/blink.gif)
I SHOULD HAVE POWDER COATED EVERYTHING! (IMG:style_emoticons/default/headbang.gif)
914werke
post May 29 2022, 11:14 AM
The lock plate works by bending the tabs up into the machined slots.
There are two (2) main types of strut housing, early/late with corresponding ball joints & hardware.
Your 74 should have LATE unless a PO changed it out for some reason
The Pin in your image is for a late strut/ball joint combo.
The Ball joint is for early
You need the right ball joints
- Lo-Fi Version Time is now: 4th November 2025 - 08:30 PM
