| ctc911ctc |
May 29 2022, 11:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,266 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
'74 2.0 - around 25K, all original
Well, I thought this would go back together simply, not a chance - so I have a few questions. 1. TAB WASHER - does this do anything? If it is intended to do anything, why do I find pictures of this thing UN-LOADED, or the tabs bending downward NOT upward. I installed this with the tabs upward, took some pressure to get the cotter pin into the holes......this seems correct, any thoughts? Also, does it really do anything? Really? (IMG:style_emoticons/default/confused24.gif) ![]() 2. Threaded Pin - I tried to get this thing in and it does not fit. Looking at the picture I bought ball-joints for up to '72! HOWEVER, the ball joints I purchased on the BirdSite are specified to fit on a '74. They do fit. HOWEVER, the Threaded pin does not. To make this MORE interesting, the AutoAtlanta website description details that their theaded pin is for '72 and later......... (IMG:style_emoticons/default/confused24.gif) QUESTION: Do I buy an older theaded pin? Do I grind the marks on the one I have to make it fit? NOTE: there are two marks from where the pin is meeting the curve of the ball joint..... (IMG:style_emoticons/default/blink.gif) ![]() I SHOULD HAVE POWDER COATED EVERYTHING! (IMG:style_emoticons/default/headbang.gif) ![]() Attached image(s)
| 914werke |
May 29 2022, 01:30 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,444 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
"The Ball joint is for early You need the right ball joints" (IMG:style_emoticons/default/confused24.gif) |
ctc911ctc Front End Rebuild - Questions May 29 2022, 11:03 AM
Shivers Those ball joints may be for the pinch bolts 68-71 May 29 2022, 11:10 AM
914werke The lock plate works by bending the tabs up into t... May 29 2022, 11:14 AM
Literati914 …there are two marks from where the pin is meeti... May 29 2022, 11:23 AM
ctc911ctc Thank you for the assistance - YES, I ordered the ... May 29 2022, 01:06 PM
rhodyguy The fastener should not stick out of the strut as ... May 29 2022, 01:48 PM
Literati914
QUESTION - …, is there a 70/71 bolt that wou... May 29 2022, 02:36 PM
QUESTION - …, is there a 70/71 bolt that wo... May 29 2022, 02:59 PM
mepstein If your ball joint has a semi circle it’s early ... May 29 2022, 02:56 PM
Superhawk996 Swap to proper late - wedge ball joints.
Suspens... May 29 2022, 03:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2025 - 08:33 PM |
