| ctc911ctc |
May 29 2022, 11:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,266 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
'74 2.0 - around 25K, all original
Well, I thought this would go back together simply, not a chance - so I have a few questions. 1. TAB WASHER - does this do anything? If it is intended to do anything, why do I find pictures of this thing UN-LOADED, or the tabs bending downward NOT upward. I installed this with the tabs upward, took some pressure to get the cotter pin into the holes......this seems correct, any thoughts? Also, does it really do anything? Really? (IMG:style_emoticons/default/confused24.gif) ![]() 2. Threaded Pin - I tried to get this thing in and it does not fit. Looking at the picture I bought ball-joints for up to '72! HOWEVER, the ball joints I purchased on the BirdSite are specified to fit on a '74. They do fit. HOWEVER, the Threaded pin does not. To make this MORE interesting, the AutoAtlanta website description details that their theaded pin is for '72 and later......... (IMG:style_emoticons/default/confused24.gif) QUESTION: Do I buy an older theaded pin? Do I grind the marks on the one I have to make it fit? NOTE: there are two marks from where the pin is meeting the curve of the ball joint..... (IMG:style_emoticons/default/blink.gif) ![]() I SHOULD HAVE POWDER COATED EVERYTHING! (IMG:style_emoticons/default/headbang.gif) ![]() Attached image(s)
| Literati914 |
May 29 2022, 02:36 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,124 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
.. QUESTION - …, is there a 70/71 bolt that would fit? is the V the only difference? No a bolt of any kind would not work, because as I mentioned, there is a cut/gap at the bottom tip of early struts (which you don’t have) - that gap is crucial for proper clamping. Apparently that set up would occasionally oval out the hole (that the ball joint fits in), so Porsche upgraded to the wedge pin design (that you have). . |
| mepstein |
May 29 2022, 02:59 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,202 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
.. QUESTION - …, is there a 70/71 bolt that would fit? is the V the only difference? No a bolt of any kind would not work, because as I mentioned, there is a cut/gap at the bottom tip of early struts (which you don’t have) - that gap is crucial for proper clamping. Apparently that set up would occasionally oval out the hole (that the ball joint fits in), so Porsche upgraded to the wedge pin design (that you have). The pinch bolt struts work fine unless the pinch bolt loosens and the car continues to get driven. Once it’s loose, it moves around and wallows out the hole. Then it’s pretty much ruined. |
ctc911ctc Front End Rebuild - Questions May 29 2022, 11:03 AM
Shivers Those ball joints may be for the pinch bolts 68-71 May 29 2022, 11:10 AM
914werke The lock plate works by bending the tabs up into t... May 29 2022, 11:14 AM
Literati914 …there are two marks from where the pin is meeti... May 29 2022, 11:23 AM
ctc911ctc Thank you for the assistance - YES, I ordered the ... May 29 2022, 01:06 PM
914werke "The Ball joint is for early
You need the ri... May 29 2022, 01:30 PM
rhodyguy The fastener should not stick out of the strut as ... May 29 2022, 01:48 PM
mepstein If your ball joint has a semi circle it’s early ... May 29 2022, 02:56 PM
Superhawk996 Swap to proper late - wedge ball joints.
Suspens... May 29 2022, 03:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2025 - 08:47 PM |
