| SVG223 |
Jun 5 2022, 10:59 PM
Member ![]() ![]() Group: Members Posts: 115 Joined: 6-February 22 From: Benton Arkansas Member No.: 26,317 Region Association: None |
My 914 overheats on the highway. I had concerns about the air flap, but I think the thermostat has broken and it stays in the open position. I thought something might be clogging the fan but it looks clear. I wonder about the heater air hose that goes over the motor. It could be blocking some air possibly. I may try to tie it out of the way. After exiting the highway and stopping at a stopsign the idle was extremely low, I was surprised it was still running. I turned the engine off for a while and it ran better after it cooled down. Any ideas would be appreciated.
| mgphoto |
Jun 6 2022, 11:02 AM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,412 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
My 914 overheats on the highway. I had concerns about the air flap, but I think the thermostat has broken and it stays in the open position. I thought something might be clogging the fan but it looks clear. I wonder about the heater air hose that goes over the motor. It could be blocking some air possibly. I may try to tie it out of the way. After exiting the highway and stopping at a stopsign the idle was extremely low, I was surprised it was still running. I turned the engine off for a while and it ran better after it cooled down. Any ideas would be appreciated. Does the engine have a catalytic converter? Clogged converter will create back pressure causing overheating. ‘76 my in California had them. |
| SVG223 |
Jun 6 2022, 05:44 PM
My 914 overheats on the highway. I had concerns about the air flap, but I think the thermostat has broken and it stays in the open position. I thought something might be clogging the fan but it looks clear. I wonder about the heater air hose that goes over the motor. It could be blocking some air possibly. I may try to tie it out of the way. After exiting the highway and stopping at a stopsign the idle was extremely low, I was surprised it was still running. I turned the engine off for a while and it ran better after it cooled down. Any ideas would be appreciated. Does the engine have a catalytic converter? Clogged converter will create back pressure causing overheating. ‘76 my in California had them. Yes, it does. I found a receipt where it was replaced in 2005 or so in California. I wouldn't mind being rid of it. I'm not sure how to check the back pressure. |
SVG223 Overheating on the highway. 76, 2.0 Jun 5 2022, 10:59 PM
Superhawk996 Did it actually go into the red zone? If not then... Jun 5 2022, 11:38 PM
SVG223
Did it actually go into the red zone? If not the... Jun 6 2022, 12:17 AM
JamesM This could be SO many things its hard to find a pl... Jun 5 2022, 11:39 PM
Superhawk996
This could be SO many things its hard to find a p... Jun 5 2022, 11:44 PM
SVG223
This could be SO many things its hard to find a p... Jun 6 2022, 12:28 AM
JamesM
This could be SO many things its hard to find a ... Jun 6 2022, 02:11 AM
SVG223
[quote name='JamesM' post='3006792' date='Jun 5 ... Jun 6 2022, 12:40 PM
JamesM
There's a little wear on second gear synchro ... Jun 6 2022, 09:06 PM
wonkipop
This could be SO many things its hard to find a p... Jun 6 2022, 02:59 AM
JamesM
i got one of those them there grommets on my engi... Jun 6 2022, 10:43 AM
wonkipop
i got one of those them there grommets on my eng... Jun 6 2022, 04:39 PM
Superhawk996 Location?
Ambient temperature?
Speed driven, wha... Jun 6 2022, 01:12 AM
SVG223
Location?
Arkansas
80f
Speed... Jun 6 2022, 11:58 AM
JamesM My gut (and my eyes with limited pictures) are tel... Jun 6 2022, 02:25 AM
76-914 As James said that is the oil temp. Porsche actual... Jun 6 2022, 08:07 AM
SVG223
As James said that is the oil temp. Porsche actua... Jun 6 2022, 05:50 PM
emerygt350 The other symptoms point to something out of the o... Jun 6 2022, 09:41 AM
Superhawk996
The other symptoms point to something out of the ... Jun 6 2022, 09:48 AM
SVG223
The other symptoms point to something out of the ... Jun 6 2022, 06:18 PM
Chaznaster
The other symptoms point to something out of the ... Jun 6 2022, 06:56 PM
Superhawk996 Here's the weekly posting of oil temperature g... Jun 6 2022, 09:41 AM
wonkipop
[quote name='mgphoto' post='3006885' date='Jun 6 ... Jun 6 2022, 07:08 PM
emerygt350 Good call. Never even thought about that. Jun 6 2022, 11:12 AM
Superhawk996 Based on info above I'm more convinced that so... Jun 6 2022, 12:17 PM
SVG223
Based on info above I'm more convinced that s... Jun 6 2022, 10:59 PM
brant Also wanted to ask which front spoiler or valance ... Jun 6 2022, 01:49 PM
wonkipop @SVG223
hey thats a good looking car you got hol... Jun 6 2022, 04:31 PM
emerygt350 1- ODYR/SLX-11-1--BLUE-K - Cylinder Head Temperatu... Jun 6 2022, 07:37 PM
FlacaProductions
1- ODYR/SLX-11-1--BLUE-K - Cylinder Head Temperat... Jun 7 2022, 09:32 AM
Chaznaster
1- ODYR/SLX-11-1--BLUE-K - Cylinder Head Temperat... Jun 8 2022, 05:40 PM
mgphoto Remove the cat, there is an after market bypass pi... Jun 6 2022, 10:52 PM
Lockwodo Don't know if anyone else has mentioned this, ... Jun 7 2022, 01:37 PM
emerygt350 That's a Porsche/diff type thing. Our fans ar... Jun 7 2022, 03:11 PM
piscean914 i would start by confirming the oil temp in the su... Jun 7 2022, 11:59 PM
rhodyguy Delete/Replace the cat converter and clean the oil... Jun 10 2022, 07:50 AM
SVG223 I think the ignition timing has been retarded by a... Apr 9 2023, 06:58 PM
Superhawk996
tried to get it to ping but it didn't so I n... Apr 9 2023, 07:47 PM
SVG223
tried to get it to ping but it didn't so I ... Apr 9 2023, 09:51 PM
VaccaRabite
[quote name='Superhawk996' post='3070615' date='A... Apr 10 2023, 09:44 AM
SVG223
[quote name='Superhawk996' post='3070615' date='... Apr 11 2023, 10:43 PM
VaccaRabite
I hear no pinging under load I may have guessed ... Apr 12 2023, 06:24 AM
SVG223
I hear no pinging under load I may have guessed... Apr 12 2023, 07:27 AM
VaccaRabite Just clearing out all the crap on top of the oil c... Apr 12 2023, 11:30 AM
930cabman Has a "high temperature" ever been confi... Apr 13 2023, 06:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 10:54 AM |
