Crankshaft gear dots, Two gears with dots in different locations |
Phoenix914 |
Jun 7 2022, 05:47 PM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
I decided to buy a new crankshaft gear because the machine shop gouged mine with a tool while disassembling the crankshaft. The new gear I bought at a local VW parts store has the two dots located one tooth over from the gear that came out of my engine. Which one is correct? The part number on the new gear is right, so now I'm not sure which gear to use.
I can simply drill some new holes in the new gear to match the old one, but can anyone confirm which one has the righ marks? New gear and box at the top, old gear at the bottom: Thanks for any help! |
Jake Raby |
Jun 8 2022, 07:07 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The dot location on the replacement leads me to believe it is a replacement made by Sebro a few years ago.
I have seen these have too large of an OD, fit too loose and create a failure years later. I only use original, genuine gears. Thanks for conforming the diameters are the same. |
Lo-Fi Version | Time is now: 17th June 2024 - 01:12 AM |
