Doing a rebuild '73 2.0 motor - heads are shot |
DC_neun_vierzehn |
Jun 11 2022, 06:52 PM
Member Group: Members Posts: 389 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
My '73 2.0 motor needs a rebuild. Different shops are recommending different approaches to replacing the heads, which are both cracked (near the spark plug holes).
One shop doesn't believe in using "Chinese crap" and wants to try and search the planet for NOS or great condition heads, but has no leads (nor do they think welding/repairing my heads is a good idea). The other shop is open to using high quality repos like the Len Hoffman 2.0 heads. What have folks used for replacement heads on a 2.0 rebuild that are performing well years later? Are there any options out there for finding NOS or top shape used 2.0 heads? FYI - keeping the motor stock - no mods on the rebuild. Thanks in advance. |
Steve H |
Jun 11 2022, 09:26 PM
Newbie Group: Members Posts: 28 Joined: 3-May 03 From: Los Angeles, Ca Member No.: 646 |
Well, you just might be in luck. I have had some NOS parts sitting in the guest bedroom closet for at least the past 15 years waiting to have a stock, GA case, 2.0L engine built from the ground up. I'm beginning to think this build might not get done. I have the following:
NOS 2.0L German Porsche/VW heads still smothered in cosmoline from the factory NOS 2.0L German Porsche/VW crankshaft smothered in cosmoline from the factory NOS 2.0L German Mahle 94mm High Comp. Pistons & Cylinders, rings and wrist pins Original GA (t-4) case. Casework has already been prepared by George at European Motorworks in Hawthorn, Ca. Case was align bored with oil galley holes drilled and tapped. Set of main bearings to match also purchased. I'm out of town until Monday but will be happy to send photos or talk if you have any interest. Please note that I'm of Norwegian Decent and not Nigerian. George at European knows me as does Bruce Stone and Leamon Stamsell from So Cal. Either way, good luck with your build. |
DC_neun_vierzehn |
Jun 12 2022, 06:18 AM
Well, you just might be in luck. I have had some NOS parts sitting in the guest bedroom closet for at least the past 15 years waiting to have a stock, GA case, 2.0L engine built from the ground up. I'm beginning to think this build might not get done. I have the following: NOS 2.0L German Porsche/VW heads still smothered in cosmoline from the factory NOS 2.0L German Porsche/VW crankshaft smothered in cosmoline from the factory NOS 2.0L German Mahle 94mm High Comp. Pistons & Cylinders, rings and wrist pins Original GA (t-4) case. Casework has already been prepared by George at European Motorworks in Hawthorn, Ca. Case was align bored with oil galley holes drilled and tapped. Set of main bearings to match also purchased. I'm out of town until Monday but will be happy to send photos or talk if you have any interest. Please note that I'm of Norwegian Decent and not Nigerian. George at European knows me as does Bruce Stone and Leamon Stamsell from So Cal. Either way, good luck with your build. @Steve_H PM sent |
Lo-Fi Version | Time is now: 6th June 2024 - 12:26 PM |
