Come on I-lean, driver lean like an s10 |
nditiz1 |
Jun 15 2022, 04:07 PM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So after getting the trailing arm rebushed on the drivers side I wanted to check the rake. The rake looks good. I checked for level port to starboard and I got a lean. Almost like the s10 lean when the big dudes drive around on them all the time and the springs get sad. Front is leaning too. So my question is - Will the rear suspension affect the front suspension in regards to balance? I realize if the driver rear is super low it will have some affect on the driver front, but its almost like a 1:1 ration where as I thought the front would not suffer as much.
Oil tank is on the driver side accounting for some of the additional weight. I was not in the car when checking the side to side level. Rear springs are 100lb 914-6 ones two perches up on both. Front is an SC setup with a front sway bar. Will new rear springs solve all my problems or do I need to investigate something else like adjust the front driver adjuster also? At the donuts Drv F - 4 & 7/8 Drv R - 5 & 7/8 Pass F - 5 & 7/8 Pass R - ~6 - hard to determine as there was console work done on that side and the donut was remounted at an angle (IMG:style_emoticons/default/headbang.gif) From those numbers it doesn't seem like the rear should have as much variation, but it does. The fender on the Pass R is about 2 in higher than the Drv R. Maybe the guy that put on the flares was careless (IMG:style_emoticons/default/confused24.gif) The lowest point seems to be the Drv F with 1 inch lower than the pass F and Drv R. So maybe if I adjust the drv F and get that donut in line with the pass F then I can start to adjust the pass R down one notch to bring it even with the drv R. Is this logic sound? Where you at Phil? (IMG:style_emoticons/default/beerchug.gif) |
nditiz1 |
Jun 16 2022, 08:09 AM
In my original post I did measure from the Donuts. Is there a better spot than that I should measure from?
The floor is level to an extent. All garage floors have a built-in slope to ensure water moves away from the back per local code. Let me play around with the front and rear adjustments and report back. |
rick 918-S |
Jun 16 2022, 09:56 AM
Hey nice rack! -Celette Group: Members Posts: 20,494 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
In my original post I did measure from the Donuts. Is there a better spot than that I should measure from? The floor is level to an extent. All garage floors have a built-in slope to ensure water moves away from the back per local code. Let me play around with the front and rear adjustments and report back. People place Jacks under the donuts and bend them. Measure from the pivot bolt for the rear suspension and the bolts for the aft side of the front rack mount with the car on a level surface. Least likely to have been damaged over the years. |
Olympic 914 |
Jun 16 2022, 10:23 AM
Group: Members Posts: 1,677 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
In my original post I did measure from the Donuts. Is there a better spot than that I should measure from? The floor is level to an extent. All garage floors have a built-in slope to ensure water moves away from the back per local code. Let me play around with the front and rear adjustments and report back. People place Jacks under the donuts and bend them. Measure from the pivot bolt for the rear suspension and the bolts for the aft side of the front rack mount with the car on a level surface. Least likely to have been damaged over the years. (IMG:style_emoticons/default/agree.gif) Did this on mine, measured from the tube on the rear suspension arm, and where the front a-arms bolt to the body. I should have put weight in the car when I set the height. I will next time. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:44 AM |
