So after getting the trailing arm rebushed on the drivers side I wanted to check the rake. The rake looks good. I checked for level port to starboard and I got a lean. Almost like the s10 lean when the big dudes drive around on them all the time and the springs get sad. Front is leaning too. So my question is - Will the rear suspension affect the front suspension in regards to balance? I realize if the driver rear is super low it will have some affect on the driver front, but its almost like a 1:1 ration where as I thought the front would not suffer as much.
Oil tank is on the driver side accounting for some of the additional weight. I was not in the car when checking the side to side level.
Rear springs are 100lb 914-6 ones two perches up on both. Front is an SC setup with a front sway bar.
Will new rear springs solve all my problems or do I need to investigate something else like adjust the front driver adjuster also?
At the donuts
Drv F - 4 & 7/8
Drv R - 5 & 7/8
Pass F - 5 & 7/8
Pass R - ~6 - hard to determine as there was console work done on that side and the donut was remounted at an angle
From those numbers it doesn't seem like the rear should have as much variation, but it does. The fender on the Pass R is about 2 in higher than the Drv R. Maybe the guy that put on the flares was careless
The lowest point seems to be the Drv F with 1 inch lower than the pass F and Drv R.
So maybe if I adjust the drv F and get that donut in line with the pass F then I can start to adjust the pass R down one notch to bring it even with the drv R. Is this logic sound? Where you at Phil?
