Come on I-lean, driver lean like an s10 |
nditiz1 |
Jun 15 2022, 04:07 PM
Senior Member Group: Members Posts: 1,180 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So after getting the trailing arm rebushed on the drivers side I wanted to check the rake. The rake looks good. I checked for level port to starboard and I got a lean. Almost like the s10 lean when the big dudes drive around on them all the time and the springs get sad. Front is leaning too. So my question is - Will the rear suspension affect the front suspension in regards to balance? I realize if the driver rear is super low it will have some affect on the driver front, but its almost like a 1:1 ration where as I thought the front would not suffer as much.
Oil tank is on the driver side accounting for some of the additional weight. I was not in the car when checking the side to side level. Rear springs are 100lb 914-6 ones two perches up on both. Front is an SC setup with a front sway bar. Will new rear springs solve all my problems or do I need to investigate something else like adjust the front driver adjuster also? At the donuts Drv F - 4 & 7/8 Drv R - 5 & 7/8 Pass F - 5 & 7/8 Pass R - ~6 - hard to determine as there was console work done on that side and the donut was remounted at an angle (IMG:style_emoticons/default/headbang.gif) From those numbers it doesn't seem like the rear should have as much variation, but it does. The fender on the Pass R is about 2 in higher than the Drv R. Maybe the guy that put on the flares was careless (IMG:style_emoticons/default/confused24.gif) The lowest point seems to be the Drv F with 1 inch lower than the pass F and Drv R. So maybe if I adjust the drv F and get that donut in line with the pass F then I can start to adjust the pass R down one notch to bring it even with the drv R. Is this logic sound? Where you at Phil? (IMG:style_emoticons/default/beerchug.gif) |
fixer34 |
Jun 15 2022, 04:19 PM
Senior Member Group: Members Posts: 1,082 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
So after getting the trailing arm rebushed on the drivers side I wanted to check the rake. The rake looks good. I checked for level port to starboard and I got a lean. Almost like the s10 lean when the big dudes drive around on them all the time and the springs get sad. Front is leaning too. So my question is - Will the rear suspension affect the front suspension in regards to balance? I realize if the driver rear is super low it will have some affect on the driver front, but its almost like a 1:1 ration where as I thought the front would not suffer as much. Oil tank is on the driver side accounting for some of the additional weight. I was not in the car when checking the side to side level. Rear springs are 100lb 914-6 ones two perches up on both. Front is an SC setup with a front sway bar. Will new rear springs solve all my problems or do I need to investigate something else like adjust the front driver adjuster also? At the donuts Drv F - 4 & 7/8 Drv R - 5 & 7/8 Pass F - 5 & 7/8 Pass R - ~6 - hard to determine as there was console work done on that side and the donut was remounted at an angle (IMG:style_emoticons/default/headbang.gif) From those numbers it doesn't seem like the rear should have as much variation, but it does. The fender on the Pass R is about 2 in higher than the Drv R. Maybe the guy that put on the flares was careless (IMG:style_emoticons/default/confused24.gif) The lowest point seems to be the Drv F with 1 inch lower than the pass F and Drv R. So maybe if I adjust the drv F and get that donut in line with the pass F then I can start to adjust the pass R down one notch to bring it even with the drv R. Is this logic sound? Where you at Phil? (IMG:style_emoticons/default/beerchug.gif) I'm not a suspension expert, but a 1" difference between the fronts sounds like a lot. I would adjust one or both torsion arms until they are equal (or nearly so-you can account for driver weight). Pretty sure there are threads on here that give all the factory specs for ride height, angles, etc. I would start there. |
Jun 15 2022, 04:58 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
nditiz1 |
Jun 15 2022, 05:22 PM
Fine!!!!!
Valvolines for reference (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1655335342.1.jpg) DR (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1655335343.2.jpg) PR (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1655335343.3.jpg) PF (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1655335344.4.jpg) DF (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1655335344.5.jpg) |
Olympic 914 |
Jun 15 2022, 05:33 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
You could try switching the spring/shock sides and see if that changes things.
and even out the front torsion bar adjustments. Disconnect the front sway bar when you do this. |
nditiz1 |
Jun 15 2022, 05:44 PM
You could try switching the spring/shock sides and see if that changes things. and even out the front torsion bar adjustments. Disconnect the front sway bar when you do this. I blame those springs you sold me Tom (IMG:style_emoticons/default/laugh.gif) j/k |
Olympic 914 |
Jun 15 2022, 05:52 PM
You could try switching the spring/shock sides and see if that changes things. and even out the front torsion bar adjustments. Disconnect the front sway bar when you do this. I blame those springs you sold me Tom (IMG:style_emoticons/default/laugh.gif) j/k Hey, My car sat level.... But I'm a skinny dude. (IMG:style_emoticons/default/confused24.gif) |
malcolm2 |
Jun 15 2022, 07:57 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I need to know more..... Eileen too.
I adjusted my adjustable shocks. Happen to remember this, cause I was under the 914 changing the gear oil last weekend. Right side is set about 5 notches higher than the left. But I still lean a bit. What is causing it? |
Jun 15 2022, 08:03 PM
Check the obvious first, like springs not seated correctly etc. Drive it around the block to make sure the suspension has settled.
Otherwise, you'll need a corner balance. And yes, changing the height on the rear will also affect the front (and vice versa). Take it to a race shop that knows old Porsche cars and have them corner balance and align the car. (IMG:style_emoticons/default/popcorn[1].gif) |
nditiz1 |
Jun 15 2022, 08:26 PM
Thanks Andy.
Anyone know who does balancing in Maryland? |
Van B |
Jun 15 2022, 09:12 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
infraredcalvin |
Jun 15 2022, 11:44 PM
Distracted Member Group: Members Posts: 1,511 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Check the obvious first, like springs not seated correctly etc. Drive it around the block to make sure the suspension has settled. Otherwise, you'll need a corner balance. And yes, changing the height on the rear will also affect the front (and vice versa). Take it to a race shop that knows old Porsche cars and have them corner balance and align the car. (IMG:style_emoticons/default/popcorn[1].gif) And be aware that a corner balance will not yield a perfect symmetry of height from side to side. Set your approximate desired ride height, then take it in. |
BeatNavy |
Jun 16 2022, 05:13 AM
Anyone know who does balancing in Maryland? Nick, try Taylor Chapman in Sterling across the river from you maybe? Otherwise consider posting on Dorkiphus (if you haven't already). There's definitely a place in Merrifield / Vienna. Just not sure where close to you in Maryland... |
rick 918-S |
Jun 16 2022, 06:57 AM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I wouldn't measure to the lip of the flare. They could be off during installation and show measurable difference.
tygaboy |
Jun 16 2022, 07:16 AM
914 Guru Group: Members Posts: 5,286 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
@Rick 918-s is spot on. When determining ride height, you'll want to measure from solid points of the chassis. These cars can have significant variation in them, particularly at the fender once flares have been installed. On my car, which I had corner balanced at a reputable race shop, the tech specifically called out not to measure at any body line. At level (chassis-wise) I have a 1/4" height difference across my front flares. And not that I'm the world's best flare installer but if you look at my build, you'll see they were installed pretty accurately in terms of fitting them to the body. |
Superhawk996 |
Jun 16 2022, 07:57 AM
914 Guru Group: Members Posts: 5,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I have a 1/4" height difference across my front flares. And not that I'm the world's best flare installer but if you look at my build, you'll see they were installed pretty accurately in terms of fitting them to the body. Ya' all are lucky -- some idiot installed my driver front fiberglass flare 3/4" too far REARward. (IMG:style_emoticons/default/av-943.gif) Totally agree with Chris and Rick -- don't measure ride height to flares! Will the rear suspension affect the front suspension in regards to balance? Yes! |
Superhawk996 |
Jun 16 2022, 08:02 AM
Disconnect the front sway bar when you do this. (IMG:style_emoticons/default/agree.gif) Sort of goes without saying . . . but . . . make sure you're on a level surface. My garage floor is not level. Is yours? Have you actually checked it? |
nditiz1 |
Jun 16 2022, 08:09 AM
In my original post I did measure from the Donuts. Is there a better spot than that I should measure from?
The floor is level to an extent. All garage floors have a built-in slope to ensure water moves away from the back per local code. Let me play around with the front and rear adjustments and report back. |
Superhawk996 |
Jun 16 2022, 08:20 AM
Doh! (IMG:style_emoticons/default/slap.gif)
Doughnuts would be fine. Why not use factory manual for front? The problem is that spec is +/- 5mm and you are way beyond that. Are you checking with full fuel? Fuel tank biases weight toward passenger side by design. Have you moved battery and/or switched to light weight battery? |
rhodyguy |
Jun 16 2022, 08:22 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,073 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
When I had my CB/alignment done, weights were put in the driver's seat approximating my poundage.
Lo-Fi Version | Time is now: 7th May 2024 - 04:02 AM |
