> Rookie transmission question, broken first repair
Charles Freeborn
post Apr 27 2022, 12:52 PM
My transmission is reported to have a broken 1st gear. Not uncommon.
I've taken one pass through the EvilWerks videos (I bought the series) and as best as my memory can provide - the 1st and reverse gears are under the outer cover and not nested inside with the rest of the gear clusters. So, here's the question: If the damage is limited to just those components can one do a diagnosis and repair without cracking open the whole gearbox? Obviously if upon inspection things like synchros, etc are worn I'm all in, but this trans is reported to be sound other than the broken 1st, but yeah, race car...
Any transmission repair advice welcomed.
Thx.
brant
post Jun 15 2022, 04:43 PM
We didn’t go with a kit
We found a good cooler and had it cleaned
Made up our own SSI lines and fittings
There is a farm pum sold at the farm and ranch stores that is all the same specs (housing and even dimensions) as the Tipton pump
Farmers use them to pump weed treat and fluid transfer on big commercial sprayers. It might be the same pump manufacturer
But it’s half the price of the Tilton. Just no Tiilton sticker
We had our guy drill holes in the case over the stack/diff/etc
He didn’t even put in a spray bar
And he has used the same set up on nearly a dozen 901’s
The AN fittings screw into the holes he drilled and tapped
I don’t remember the AN size. Probably -8
The cooler should be sized for the same
Charles Freeborn
post Jun 15 2022, 06:58 PM
Great ideas. Thanks. I imagine a significant benefit is simply having more oil capacity and it being cooled is a plus.
QUOTE(brant @ Jun 15 2022, 03:43 PM) *
stownsen914
post Jun 17 2022, 04:56 PM
You can even use the oil fill and oil drain plugs as inlet and outlet for the oil. For modest hp applications, you can get away without a spray bar. Just cooling the oil is good enough. I ran my car for a number of years without a cooler. The trans seemed to hold up OK, but shifting would get a little notchy by the end of 25 minutes sessions. The cooler helped that.
Charles Freeborn   Rookie transmission question   Apr 27 2022, 12:52 PM
914werke   Broken..? First start with issue/symptoms what it ...   Apr 27 2022, 01:57 PM
Tdskip   Popping out of gear I assume?   Apr 27 2022, 02:19 PM
Charles Freeborn   Not sure. Engine and trans were both out when I g...   Apr 27 2022, 04:39 PM
mepstein   It’s false economy to just look at part of the t...   Apr 27 2022, 04:56 PM
brant   It’s false economy to just look at part of the ...   Apr 27 2022, 05:37 PM
stownsen914   It's easy to pop the rear cover off the trans ...   Apr 27 2022, 09:07 PM
Charles Freeborn   It's easy to pop the rear cover off the trans...   Apr 28 2022, 10:41 AM
Charles Freeborn   Well... I tore it apart today with the help of a l...   May 18 2022, 05:40 PM
mepstein   Cool find on the 904 main shaft.   May 18 2022, 05:55 PM
Charles Freeborn   Aaaaand the carnage: 1st/Rev stack destroy...   May 20 2022, 06:05 PM
wndsrfr   Aaaaand the carnage: 1st/Rev stack destro...   May 21 2022, 10:32 AM
Charles Freeborn   Aaaaand the carnage: 1st/Rev stack destr...   May 22 2022, 04:48 PM
Charles Freeborn   Trans going back together. The only parts salvagea...   Jun 15 2022, 09:34 AM
brant   Just advice I wish I had followed the advice myse...   Jun 15 2022, 02:33 PM
Charles Freeborn   Good advice - especially if enduros are in the mix...   Jun 15 2022, 04:03 PM
brant   We didn’t go with a kit We found a good cooler a...   Jun 15 2022, 04:43 PM
Charles Freeborn   Great ideas. Thanks. I imagine a significant benef...   Jun 15 2022, 06:58 PM
stownsen914   You can even use the oil fill and oil drain plugs ...   Jun 17 2022, 04:56 PM
914werke   Wow! Carnage~   Jun 17 2022, 06:08 PM
Charles Freeborn   Wow! Carnage~ Yeah, it was chewed. Sorted ...   Jun 18 2022, 09:56 AM
- Lo-Fi Version Time is now: 17th July 2025 - 07:15 PM
