SOLD - Have Decided to sell my Marathon Blue '73 1.7 $7,250 |
jrmdir |
Jun 18 2022, 12:28 PM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Hi everyone: Please see http://www.914world.com/bbs2/index.php?showtopic=360275 for pricing.
Viewer Discretion Notice! In case you find “what’s my car worth” posts to be annoying, be aware this is a fairly long and possibly boring note about my car’s status and my reasons for wanting to sell. But on the plus side, hopefully, at least I’m not a newbie and have been pretty active here in the past 14 months. Learned a ton of things and hopefully contributed a some good stuff as well. And perhaps knowing this car is headed for the market will be of interest to some of you or your friends. The Background Purchased locally a year ago. Had been stored for 3-years prior. Was not running Other than being told it came from Cincinnati before the Seller owned it in Dayton, I have no history Rust issue fully disclosed, inspected by me and taken into account in the purchase price. I’m an OCD fix-it guy and wanted a post-Covid project. Also thought it could become my next (final) full on restoration project. I really enjoyed putting tons of work into getting it running and fixing numerous small issues and some big ones e.g. Fresh Air Fan. (see full list below) Have turned it into a very fun runabout that looks awesome (from 20 ft.) Next in line would be rust, body and paint work – but I’ve now figured out this is as far as I'm capable of taking it at this point (and age) And besides, it now seems too nice to think about taking it off the road for such a long time. But it will need to be done at some point for sure. I could have a lot of fun with it this summer but the time is right for me to let it go I think it has enough appeal and rarity to do pretty well on auction sites. (even with the rust fully disclosed, of course) But countering that is the fact that auctions are a hassle so I'm not sure which route to take. The Ask Selling it here on the World has a lot of appeal, but I need a price. So with all that I guess I’m blatantly trolling for thoughts & opinions on value/asking price – as well as the best way to market it. I’ll add as many photos as I’m allowed below and questions are welcomed. The Bad Hell hole is indeed hellish Rear third of the passenger long needs repair, as does the rear 1/4 of the driver side. Same goes for both rear jacking points and the tow hook bracket beneath the drivers foot well Needs paint and minor body work The Not Too Bad It’s easy to beat the 1st gear Synchro (surprise!) Front shocks are shot. I have a replacement set of used Boges that I’ve yet to install Both side roll up windows are chipped at the top. PO sourced correct original windows that have not been installed. They are included A couple of the heater tracks in the rear window need to be repaired with conductive paint (not that I think anyone really ever needs it) One straight crack in the dash top roll – which seems to be a standard feature on many of these cars. Not much of a detraction - see photo Vertical crack in the driver's door top roll pad - taped over. Original shift knob looks good but is cracked at the bottom end. Original Hella interior lamp with chrome surround and white switch is still there, but shows signs of prior melting (not unusual I understand) The Good Marathon Blue! L 96 M Very Rare Rear Window Defroster Gurney/Western Wheels with rare Porsche crest center cups About as original as they come! Engine has never been out, nothing missing except front bumper extensions, rear heat control valves and trunk & frunk carpeting. Original radio replaced at some point with period-suitable push button cassette radio Currently has larger diameter exhaust pipes from a 1.8 with the HE shields removed. Mated to Sebring/Monza muffler. I sourced a pair of correct 1.7 HE’s in great shape but have not yet installed Tons of work and $ put in to reviving the D Jet system. (see list) Starts instantly cold or hot. No smoke PO spent $3,400 on it in 2018, including rebuilding frozen rear calipers. Only the tiniest amount of oil seepage from above the filter (from the cooler?) Doesn’t drip on the floor Interior is 7 or maybe better? Only a couple of small separations in the basket weave of the driver’s seat and the above mentioned dash crack. Brand new door cards. Like new Lloyd's floor mats Everything works – all lights, switches, latches etc. (except the notorious and long gone seatbelt interlock relay and wiring.) Floors and front & rear trunks have cosmetic rust only and are very solid (will post more photos when I list it.) Rear suspension consoles are also very solid Door gaps are perfect While it does need to be repainted, it has a nice uniform patina that is almost in vogue? FWIW Original top in excellent condition New rear shocks & springs New fresh air motor and fan Shifts smoothly, pulls strongly in all gears All locks + ignition are keyed the same as original Bodywork is very straight (one small dent in front left fender), Chrome bumpers are awesome! Clear Ohio title The List Flushed and cleaned fuel tank New filter, tank strainer screen and Bosch fuel pump New hi-pressure flexible fuel lines New cap, rotor, coil, condenser, wires and plugs New PCV valve New Throttle Position Sensor (TPS) Circuit Board Rebuilt and calibrated Manifold Pressure Sensor (MPS) Replaced and/or repaired all vacuum lines Confirmed proper operation of Auxiliary Air Regulator (AAR) Adjusted fuel pressure to proper setting Tested and confirmed all ECU connections and input/output signals Changed engine oil and filter Changed gearbox lube Replaced shifter rear ball socket insert Installed all new pushrod tube o-rings and seals Installed new copper exhaust gaskets Repaired broken left hinge on rear trunk Cleaned and lubricated all locks and window mechanisms Restored battery tray/ECU mount and fabricated sturdy battery support Replaced/repaired door jamb switches and interior light Repaired Odometer Repaired both license plate lights Repaired front left marker/turn signal housing and bulb holder Repaired horn wiring in steering column Repaired turn signal cancellation and gauge indicator arrow operation Cleaned out and restored Fresh Air blower unit with new motor/fan assembly. All 3 speeds work from dash control unit. Sourced original 1.7L heat exchangers Thanks, Ron |
Montreal914 |
Jun 18 2022, 01:07 PM
Senior Member Group: Members Posts: 1,571 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
As mentioned above, the rules are that you set a price.
Although, the interior of the car is in decent condition for it's age, the car will need serious rust repair and paint. Yes, you got it back running with a good "tune-up" job, but the fact remains that this car isn't really structurally safe in this condition. Although it seems like this car could be regularly driven, I think it is a 1.7 project car. 4-6k$ is my guess but I am no expert. (IMG:style_emoticons/default/popcorn[1].gif) GLWTS (IMG:style_emoticons/default/smile.gif) |
Superhawk996 |
Jun 19 2022, 05:13 AM
914 Guru Group: Members Posts: 5,876 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Although, the interior of the car is in decent condition for it's age, the car will need serious rust repair and paint. Yes, you got it back running with a good "tune-up" job, but the fact remains that this car isn't really structurally safe in this condition. Although it seems like this car could be regularly driven, I think it is a 1.7 project car. 4-6k$ is my guess but I am no expert. (IMG:style_emoticons/default/popcorn[1].gif) GLWTS (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/agree.gif) Hundreds upon hundreds of hours of metal work will be required to correct the rust damage. Then a paint job at the end. Won’t be cheap to fix it properly. Not financially viable unless someone does the work themselves - someone looking for a project. Although car looks nice from a distance, it is what it is. It is awesome that you’ve done some work on it and fixed some annoyances. However, sunk costs have no bearing on value. Probably toward the high end - maybe $7k because it can be shown that it runs and drives? |
Lo-Fi Version | Time is now: 1st June 2024 - 06:19 PM |
