Window winder - help |
Biggles |
Jun 19 2022, 03:07 AM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
Hi All
The plastic trim on my window winder is broken. Is there a special way to get the handle off to replace the trim? Also can you get just the plastic trim and not the entire handle? Attached thumbnail(s) |
FlacaProductions |
Jun 19 2022, 08:52 AM
Senior Member Group: Members Posts: 1,607 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
https://914rubber.com/chrome-window-crank-1
among others.... |
porschetub |
Jun 19 2022, 05:24 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
(IMG:style_emoticons/default/agree.gif) most likely the best source,I ended up buying 2 sets as the first set were rubbish,and the second set were better from a different seller. The first set the plastic trim cover was poorly made and would have soon broken like the op has,however the biggest issue is the cast spline was a very loose fit on my regulator resulting in the handle rubbing on the the door trim panel. Sort of buyer beware really ?. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:18 PM |
