Ampex351 |
Member ![]() ![]() Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest ![]() |
https://dallas.craigslist.org/ndf/ctd/d/mck...7490794703.html
This car is for sale. I found out about all kinds of things needing replacement or repairing. The body is really not perfect. He was offering to me for $18,500. Does that sound good considering it could use paint, there's rust bubbles here and there. But it has great mechanicals. Motor is rebuit and brakes, etc. What's a price that would make you move? |
nathanxnathan |
Member ![]() ![]() Group: Members Posts: 291 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California ![]() |
The hellhole repair does look a bit suspect, it's hard to tell but if that's rust bubbling up from under the patch I'd probably run away.
![]() I can't tell what's going on with the throttle cable, where it's coming from — looks like it comes from the ignition box or it has a right angle in it. (IMG:style_emoticons/default/laugh.gif) The bracket seems a bit much. I'm not sure what's been done to the fan shroud to have a mount there.. Looks like the cooling flaps are removed for one thing. Just the 1 bolt to some added on ear to the fanshroud, and leaning on the breather ... actually it looks different in the other pic, not sure.. ![]() The linkage in general looks funky, the angle of the arms by the carbs seems problematic. I'd mount the fuel filter to something or get it out of the engine compartment. That wiring looks pretty rigged. (IMG:style_emoticons/default/huh.gif) Beautiful-looking car though. |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,403 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
The hellhole repair does look a bit suspect, it's hard to tell but if that's rust bubbling up from under the patch I'd probably run away. ![]() I can't tell what's going on with the throttle cable, where it's coming from — looks like it comes from the ignition box or it has a right angle in it. (IMG:style_emoticons/default/laugh.gif) The bracket seems a bit much. I'm not sure what's been done to the fan shroud to have a mount there.. Looks like the cooling flaps are removed for one thing. Just the 1 bolt to some added on ear to the fanshroud, and leaning on the breather ... actually it looks different in the other pic, not sure.. ![]() The linkage in general looks funky, the angle of the arms by the carbs seems problematic. I'd mount the fuel filter to something or get it out of the engine compartment. That wiring looks pretty rigged. (IMG:style_emoticons/default/huh.gif) Beautiful-looking car though. well spotted on the odd throttle cable bracket. its bolted on where the cooling flap "axle" rod is usually fixed. which takes your eye to immediately nearby. where there is something a bit strange going on with the oil filler cap and pcv valve. its a 1.8 L jet oil cap but it isn't a 1.8 pcv valve. the fume line is coming out of the wrong place. not sure where that oil cap and pcv valve is from. a bus? a 412? |
Lo-Fi Version | Time is now: 10th June 2024 - 06:09 PM |
