> Tires rubbing, Inside & out
NARP74
post Jul 5 2022, 10:35 PM
Rubbing on the inside fender well on the right rear, passenger side. Rubbing on the outside fender on the left rear driver side. Showing a little heat in the paint on the left side. I may need to go to a smaller size tire in the back, they are staggered now. Can the arms be adjusted or shimmed? Seems like they are not centering the wheels in the openings. Just starting to work on a new project.
StarBear
post Jul 6 2022, 09:10 AM
Just got the shim pack kits from 914Rubber. Includes o-ring washers and bolt end caps!
NARP74
post Jul 6 2022, 09:31 AM
QUOTE(StarBear @ Jul 6 2022, 09:10 AM) *
Thanks for the tip. Douglas Adams fan?
StarBear
post Jul 6 2022, 09:48 AM
QUOTE(NARP74 @ Jul 6 2022, 11:31 AM) *
Yep! Good catch. in 1981 I almost bought a house with street address "42" but it had an in-ground oil tank and asbestos around the furnace. Bought "48" instead.
NARP74   Tires rubbing   Jul 5 2022, 10:35 PM
steuspeed   What wheel tire combos are you running?   Jul 6 2022, 12:53 AM
Chris914n6   Check the camber.   Jul 6 2022, 01:19 AM
Front yard mechanic   Tires rubbing is a good thing . It means your car ...   Jul 6 2022, 06:20 AM
NARP74   Not sure which of the 2 POs installed these; Rear ...   Jul 6 2022, 08:40 AM
burton73   Not sure which of the 2 POs installed these; Rear...   Jul 6 2022, 10:25 AM
StarBear   Just got the shim pack kits from 914Rubber. Includ...   Jul 6 2022, 09:10 AM
NARP74   Just got the shim pack kits from 914Rubber. Inclu...   Jul 6 2022, 09:31 AM
StarBear   Just got the shim pack kits from 914Rubber. Incl...   Jul 6 2022, 09:48 AM
NARP74   That would have been the ultimate! 48 not so ...   Jul 6 2022, 10:11 AM
StarBear   That would have been the ultimate! 48 not so...   Jul 6 2022, 11:43 AM
NARP74   That would have been the ultimate! 48 not s...   Jul 6 2022, 11:51 AM
StarBear   That would have been the ultimate! 48 not so...   Jul 6 2022, 03:11 PM
NARP74   That would have been the ultimate! 48 not s...   Jul 6 2022, 03:45 PM
NARP74   No flares, I'll check on the wheel number late...   Jul 6 2022, 10:37 AM
SirAndy   No flares, I'll check on the wheel number lat...   Jul 6 2022, 10:42 AM
NARP74   No flares, I'll check on the wheel number la...   Jul 6 2022, 10:44 AM
infraredcalvin   No flares, I'll check on the wheel number la...   Jul 6 2022, 05:43 PM
StarBear   I’ll buy the Gargleblasters! :beer1:   Jul 6 2022, 02:39 PM
NARP74   I’ll buy the Gargleblasters! :beer1: :D   Jul 6 2022, 02:45 PM
NARP74   So can the rear arms be adjusted laterally? Answe...   Jul 6 2022, 04:54 PM
NARP74   951362.117 AS10.62   Jul 6 2022, 08:52 PM
sixnotfour   951 8's ,,I had 245 /45s on a narrow car fit ...   Jul 6 2022, 09:04 PM
NARP74   So what are my options? Metal work, inner fender a...   Jul 14 2022, 11:56 AM
Chris914n6   Can I run one wheel spacer for the side touching ...   Jul 15 2022, 12:33 PM
Dave_Darling   If you sell the 8s, you should have enough $...   Jul 15 2022, 07:12 PM
ndfrigi   check my post #15426 if it will help. http://www....   Jul 15 2022, 07:16 PM
NARP74   Thanks for the replies. I'll mount the fronts...   Jul 15 2022, 08:42 PM
NARP74   Not sure why it rotated my pic. Click on it and i...   Jul 15 2022, 08:53 PM
NARP74   The lips on my rear fenders have already been roll...   Jul 16 2022, 02:19 PM
NARP74   I have read that the 951 wheels were used for adde...   Aug 8 2022, 09:18 AM
infraredcalvin   No, the 951 8” Fuchs is not the same specs as th...   Aug 8 2022, 04:15 PM
targa72e   951 are rare as they were a one year option on 86 ...   Aug 8 2022, 10:12 PM
NARP74   951 are rare as they were a one year option on 86...   Aug 9 2022, 03:48 PM
- Lo-Fi Version Time is now: 16th June 2024 - 08:01 PM
