| 914ltd |
Apr 22 2015, 10:25 AM
Member ![]() ![]() Group: Members Posts: 245 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None
Hi all
My last batch of new 13" Bosch blades will not work (properly) on 914 and 911-912 wiper arms. They now only have clips for 9mm arms. Any solutions?? Thanks, Brad |
| StarBear |
Feb 1 2022, 12:36 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Gee, wish I would have found this thread two weeks ago. Just got a pair (964-628-901-02-M14) from Pelican - they don't fit on original wiper arms despite the "fitment" indication. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/chair.gif)
Fortunately my old clips are good so will follow the advice posted earlier. Seems like this problem is ongoing. (IMG:style_emoticons/default/sad.gif) |
| soterik |
Jul 8 2022, 06:53 PM
Newbie ![]() Group: Members Posts: 1 Joined: 30-November 05 From: seattle, wa Member No.: 5,212 |
Gee, wish I would have found this thread two weeks ago. Just got a pair (964-628-901-02-M14) from Pelican - they don't fit on original wiper arms despite the "fitment" indication. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/chair.gif) Fortunately my old clips are good so will follow the advice posted earlier. Seems like this problem is ongoing. (IMG:style_emoticons/default/sad.gif) I've been making the correct wiper arms and blades for 10 years. They are exact copies of the original SWF version. I also make the RHD version as well. I'm using the very early steel clip around the pivot point rather than the plastic one which will get brittle and break, I changed to that on my second run of them. $50 a pair for the arms, and $40 pair for the blades. Older picture on the arms, they have a bit more "bow" in them. Sorry, I don't have rubber insert separately. Tks, Eric www.autoforeignservices.com Attached image(s)
914ltd Bosch wiper blades Apr 22 2015, 10:25 AM
SirAndy Weird. I just bought a set from my local Flaps may... Apr 22 2015, 10:40 AM
r_towle just bought a set of bosch and they would not fit.... Apr 22 2015, 10:45 AM
green914 I bought a set of Bosch wiper blades last month ha... Apr 22 2015, 01:14 PM
Tom_T Andy may have a set from the older batch that stil... Apr 22 2015, 01:14 PM
Larmo63 I bought these…..
http://www.ebay.com/itm/Porsc... Apr 22 2015, 01:27 PM
Larmo63 Or, these, just for the blades……correct 13.25... Apr 22 2015, 01:29 PM
914ltd This is the only Bosch arm adapter that even comes... Apr 22 2015, 08:10 PM
somd914 Two weeks ago I bought a set of Bosch MicroEdge bl... Apr 22 2015, 08:24 PM
andys Same experience with the Bosch wipers blades. Retu... Apr 22 2015, 08:45 PM
rgalla9146 Off topic a bit.
Long ago I heard that if a car ... Apr 22 2015, 08:47 PM
Larmo63 There is a bulletin in the technical manual on thi... Apr 22 2015, 08:51 PM
GeorgeRud I finally gave up on the Bosch blades as they seem... Apr 23 2015, 12:46 PM
r_towle
I finally gave up on the Bosch blades as they see... Apr 23 2015, 01:24 PM
somd914
I finally gave up on the Bosch blades as they see... Apr 25 2015, 07:40 AM
r_towle :bump: Apr 25 2015, 07:32 AM
GeorgeRud I bought the PIAA blades on Amazon, but even thoug... Apr 25 2015, 05:27 PM
914_7T3 Resurrecting this thread as my new Bosch wiper bla... Feb 24 2020, 08:06 PM
914ltd I found these Trico blades. 13" black 7mm arm... Feb 25 2020, 10:48 AM
dr914@autoatlanta.com we try to use the original SWF or valeo blades no ... Feb 25 2020, 11:31 AM
eric9144 Interesting timing as I just had to do a 3.5hr dri... Feb 25 2020, 12:20 PM
914_7T3
Interesting timing as I just had to do a 3.5hr dr... Feb 25 2020, 05:41 PM
FlacaProductions Got these from Wiperbladesusa.com - perfect fit.
Feb 25 2020, 03:40 PM
bbrock These adapters look interesting: https://smile.ama... Feb 25 2020, 08:01 PM
914_7T3
These adapters look interesting: https://smile.am... Feb 26 2020, 02:36 PM
bbrock
[quote name='bbrock' post='2789167' date='Feb 25 ... Feb 26 2020, 03:58 PM
914_7T3
[quote name='bbrock' post='2789167' date='Feb 25... Feb 26 2020, 04:20 PM
914_7T3
[quote name='bbrock' post='2789167' date='Feb 25 ... Mar 2 2020, 11:09 PM
bbrock
[quote name='bbrock' post='2789167' date='Feb 25... Mar 2 2020, 11:23 PM
Mikey914 Yes we could make a clip that would work if necess... Feb 25 2020, 08:27 PM
Mark Henry
Yes we could make a clip that would work if neces... Feb 26 2020, 06:40 AM
Mikey914 Yes that is fairly easy. The dies cost a bit and I... Feb 26 2020, 11:11 AM
914_7T3 Add these POS blades to the list with Bosch that d... Feb 26 2020, 02:31 PM
mxkinn01 The last set I bought for my bug was the same. I ... Feb 26 2020, 03:21 PM
eric9144 Porsche Classic is now listing wipers:
http://www... Feb 26 2020, 05:31 PM
914_7T3
http://ww... Feb 26 2020, 05:53 PM
Mark Henry If you have the new bosch blades I may have figure... Feb 29 2020, 04:49 PM
Mikey914 WOW
Should we really have to modify wiper blades t... Feb 29 2020, 06:13 PM
bbrock
WOW
Should we really have to modify wiper blades ... Feb 29 2020, 09:24 PM
914_7T3
WOW
Should we really have to modify wiper blades... Feb 29 2020, 11:36 PM
Mikey914 Yes if there is a solution that looks stock no nee... Mar 1 2020, 02:04 AM
eric9144 Got my new Bosch MicroEdge wipers from amazon yest... Mar 1 2020, 10:00 AM
Johny Blackstain New Bosch wipers do have some honking plastic, so ... Mar 1 2020, 11:21 AM
914_7T3 Anybody know if this is the correct clip? If so, ... Mar 2 2020, 11:32 PM
DRPHIL914
Anybody know if this is the correct clip? If so,... Mar 3 2020, 08:03 AM
bbrock Here are the clips I just took off my 30+ year old... Mar 3 2020, 09:09 AM
914_7T3 V..........Victory!
Mar 8 2020, 06:09 PM
FlacaProductions So...what was the final answer? Mar 8 2020, 06:38 PM
914_7T3
Found them at o... Mar 8 2020, 08:06 PM
Mikey914 I'll bring in a few of these so they will be e... Mar 8 2020, 11:34 PM
Root_Werks I ordered a few of each, if you click this search ... Mar 10 2020, 04:30 PM
rgalla9146
I ordered a few of each, if you click this search... Mar 11 2020, 07:38 PM
914_7T3
[quote name='Root_Werks' post='2793007' date='Mar... Mar 11 2020, 09:57 PM
Root_Werks
[quote name='Root_Werks' post='2793007' date='Mar... Mar 12 2020, 08:46 AM
Mikey914 Glad I got 2 sets while I could. Looks like I... Mar 12 2020, 01:26 AM
bbrock
Glad I got 2 sets while I could. Looks like I... Mar 12 2020, 07:42 AM
Frankvw I am no expert, but the pictures from bbrock look ... Aug 21 2020, 05:21 AM
Literati914
Anybody know if this is the correct clip? If so,... Apr 24 2024, 11:51 AM
914_7T3
[quote name='914_7T3' post='2790986' date='Mar 3 ... May 3 2024, 07:59 AM
914Sixer Clip has to be 7mm wide for arm to work properly Apr 24 2024, 12:06 PM
Literati914
... Apr 24 2024, 01:51 PM
Literati914 Just got a reply from the ebay seller for the link... Apr 24 2024, 03:52 PM
chmillman Just in case, I found what look like a good replac... Sep 23 2024, 03:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2025 - 01:19 PM |
