How did you mount dual pole oil pressure sender |
cgnj |
Jul 12 2022, 08:28 AM
Senior Member Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Almost ready to wake up the 2270 after dropping the motor to change oil pump & oil pressure relief circuit. How and where did you mount the dual pole sender. I am using a braided steel hose.
Thanks in advance |
nathanxnathan |
Jul 12 2022, 06:32 PM
Member Group: Members Posts: 291 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
When I ran a dual pole sensor and a larger Mallory Distributor, I had found (I forget where) a braided stainless line and made a bracket (just a length of flat steel with holes drilled at each end) to mount to the nearest case parting bolt. The NPT thread of the sensor would snug down on the bracket just as it sealed on the tapered thread.
I think it was npt at both ends (male at 1 female at he other) which isn't really the best imo, though it was allegedly made for that application. I do think the dual pole senders are all tapered thread? I maintain that the hole in the case wasn't originally. |
Lo-Fi Version | Time is now: 10th June 2024 - 10:48 PM |
