914 brake calipers, Original calipers really,really bad |
ghettojet |
Jul 17 2022, 10:09 AM
Newbie Group: Members Posts: 6 Joined: 20-March 22 From: queens new york Member No.: 26,409 Region Association: North East States |
Hi!
74 1.8 basket case. So i went through the brake system master cylinder,front calipers and 90% of lines hoses are really bad. Calipers look like they came off the seabed.Pressure regulator looks ok. Found a Master and lines and hoses not to difficult but the calipers are seeming really hard to locate. Is there any sort of work around with a different caliper. iread about 320i bmw calipers work with some machining but it those aren't really everywhere either. going to check parts classifieds here but if anyone has any advice thank you! Sam Queens N.Y. |
brant |
Jul 17 2022, 10:18 AM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
PMB
Really the 320 calipers are not an upgrade The often work better only because people put rebuilt calipers on when the stock brakes work just as well if they also get rebuilt PMB will have everything you need and make sure to use good pads upgraded from stock/cheap pads to take your brakes up a level |
Lo-Fi Version | Time is now: 7th June 2024 - 07:05 AM |
